Trouble codes p0200, p0261, p0273
Howdy everyone -
The check engine light came on in my dad's truck yesterday. He had the codes checked, and it is showing p0200, p0261, p0273. From what I can find looking through the 6.0 spreadsheet, the second two are injector 1 and 5 issues, but I can't find the meaning of the 200 code.
He said that there are no noticeable changes in the way the truck runs... no smoke, no rough idle, no hard start, etc. The light came on in the middle of a 20 mile ride yesterday, and he's driven the truck 30-40 miles since then (had to get home) without any issues.
What is the best way to tell if this codes are truly for injectors, or if it is an FICM issue?
FYI, he has a 2006 F250 with ~40k miles on it. The truck is bone stock, and he does not have any kind of scan tool or gauges (even though I've been trying to convince him to get some for two years). Of course the extended warranty ran out literally three weeks ago. He's going to take it to the dealer on Monday and see if they can do anything for him, but I'm trying to do some research for him in the meantime.
Let me know if you need any other info in order to help guide me. I have the same truck, but thankfully I have not had any issues yet.
Thanks for the help!
- Steve
- Steve
P0200 simply says injector circuit--0261 and 0273 are low circuit codes, which normally mean FICM. Do the FICM voltage test at home before you take it to the dealer. All you need is a DVOM, 8mm or 5/16" wrench, and a torx bit to fit the FICM inspection cover. The procedure is in the tech folder. If it's a failed FICM send it here: FICM Repair.com - Your Source for FICM Repair Ed Stefan can fix you up for a VERY reasonable price and great customer service.
The following users liked this post:
Thanks for the tip. I've seen a couple of posts before on how to test it, but if there a good set of instructions somewhere? I'll have a hard time talking my dad into doing this over the phone, but if I can send him some directions, that would be great.
Also, I have a Insight CTS that measures FICM voltage... could I use that to troubleshoot (assuming I can get to his truck in the next week?
Is there any danger to drive the truck as is?
<TABLE width="95%"><TBODY><TR><TD></TD><TD align=right>Procedure revision date: 10/29/2009
</TD></TR></TBODY></TABLE>
<HR><TABLE cellSpacing=0 width="95%"><TBODY><TR><TD>P: Misfire/Injector Driver Circuit Operation
</TD><TD width="25%" align=right> P: Introduction </TD></TR></TBODY></TABLE>
<HR>
P1 PRELIMINARY DIAGNOSIS
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">For DTCs P0261, P0264, P0267, P0270, P0273, P0276, P0279 and P0282, when all 8 fuel injector DTCs are retrieved together.
GO to Pinpoint Test S .
For DTCs P0261, P0264, P0267, P0270, P0273, P0276, P0279 or P0282, GO to P2 .
For DTCs P0262, P0265, P0268, P0271, P0274, P0277, P0280 or P0283, GO to P5 .
For DTCs P0301, P0302, P0303, P0304, P0305, P0306, P0307 or P0308, GO to P8 .
For DTCs P0263, P0266, P0269, P0272, P0275, P0278, P0281 or P0284, GO to P9 . </TD><TD width="50%">Unable to duplicate the condition. Attempt to duplicate the condition with a warm engine if previous attempts were with a cold engine. CHECK for a loose connection, and damaged or corroded terminals. WIGGLE the harness attempting to recreate the concern. REPAIR as necessary. REFER to Section 3, No DTCs Present Symptom Chart Index, if a driveability concern exists or complete the Performance Diagnostic Form to isolate the cause of the condition. </TD></TR></TBODY></TABLE>
P2 DIAGNOSTIC TROUBLE CODES (DTCS) P0261, P0264, P0267, P0270, P0273, P0276, P0279, OR P0282
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to P3 . </TD><TD width="50%">INSTALL a new Fuel Injector.
REFER to the Workshop Manual Section 303-04, Fuel Charging and Controls.
CLEAR the DTCs. REPEAT the self-test. </TD></TR></TBODY></TABLE>
P3 CHECK FOR SHORTS IN THE INJECTOR
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to P4 . </TD><TD width="50%">INSTALL a new Fuel Injector. REFER to the Workshop Manual Section 303-04, Fuel Charging and Controls.
P4 CHECK THE FUEL INJECTOR CIRCUITS FOR AN OPEN
<TABLE border=1 cellSpacing=0 cellPadding=3 width="92%"><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">INSPECT the FICM connectors for corrosion, spread terminals and pushed-out terminals. REPAIR as necessary. If OK, INSTALL a new FICM. REFER to the Workshop Manual Section 303-14, Electronic Engine Controls.
CLEAR the DTCs. REPEAT the self-test. </TD><TD width="50%">REPAIR the open circuit. CLEAR the DTCs. REPEAT the self-test. </TD></TR></TBODY></TABLE>
<HR>
- Measure the resistance between:
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH vAlign=bottom align=middle>( + ) Fuel Injector Connector, Component Side</TH><TH vAlign=bottom align=middle>( - ) Fuel Injector Connector, Component Side</TH></TR><TR><TD vAlign=top align=left>Fuel Injector, Open Coil, Power - Pin 1</TD><TD vAlign=top align=left>Fuel Injector, Close Coil, Power - Pin 3</TD></TR><TR><TD vAlign=top align=left>Fuel Injector, Open Coil, Power - Pin 1</TD><TD vAlign=top align=left>Fuel Injector, Close Coil, Ground - Pin 4</TD></TR><TR><TD vAlign=top align=left>Fuel Injector, Open Coil, Ground - Pin 2</TD><TD vAlign=top align=left>Fuel Injector, Close Coil, Power - Pin 3</TD></TR><TR><TD vAlign=top align=left>Fuel Injector, Open Coil, Ground - Pin 2</TD><TD vAlign=top align=left>Fuel Injector, Close Coil, Ground - Pin 4</TD></TR></TBODY></TABLE>
- Suspect FICM connector disconnected.
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH vAlign=bottom align=middle>( + ) Fuel Injector Connector, Harness Side</TH><TH vAlign=bottom align=middle>( - ) Suspect FICM Connector, Harness Side</TH></TR><TR><TD vAlign=top align=left>Fuel Injector, Open Coil, Power - Pin 1</TD><TD vAlign=top align=left>Fuel Injector, Open Coil, Power</TD></TR><TR><TD vAlign=top align=left>Fuel Injector, Close Coil, Power - Pin 3</TD><TD vAlign=top align=left>Fuel Injector, Close Coil, Power</TD></TR><TR><TD vAlign=top align=left>Fuel Injector, Open Coil, Ground - Pin 2</TD><TD vAlign=top align=left>Fuel Injector, Open Coil, Ground</TD></TR><TR><TD vAlign=top align=left>Fuel Injector, Close Coil, Ground - Pin 4</TD><TD vAlign=top align=left>Fuel Injector, Close Coil, Ground</TD></TR></TBODY></TABLE>
Tim Young
6.7L Power Stroke Diesel
06-03-2018 09:02 PM
Ricson
10-17-2011 08:22 PM
wera racer
02-01-2005 07:49 PM
