'70 F100/250 4x4 kingpin: Where can I get one? HELP!
I've got a Spicer Dana 44 high pinion 4x4 front axle from the 1966-1971 vintage Fords, like from an F100. This axle has kingpins and not ball joints. I NEED ONE!! It's broken and I haven't been able to locate one yet. Anyone got suggestions?
Being the lower pin I am not having much luck with searches either. A site you might check is powerblocktv.com. Check out the extreme 4x4 section. They might have a supplier that can help. You can always have a local machine shop build one. I know but if it comes down to it that would be an option.
Ok I may have good news for you. A place called truck parts in Indianapolis, IN. Talk to Paul. I called, he needs your build number. It is usually found on the short tube of the axle housing. Stamped on the inspection side of the tube. Should start with a 6 with 6 digits a space and 2 more digits. He can be reached at 317-247-5821. Seemed like it was no big deal to him.
Applications: 1966/71 F100 4WD ~ Front Driving Axle parts shown here in an exploded view: 1964/72 Ford Truck Parts Catalog / Illustration Section 30, Page 10.
ELMER HARE FORD in Marshall MO has 1 = 660-886-7462.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
TISON MOTOR CO. in Estill SC has 1 = 803-6252551.-
KAHOKA MOTOR CO. in Kahoka MO has 2 = 660-727-2181.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghampton NY has 3 = 607-722-5371.
montego69
WTB - Parts & other
05-13-2010 03:01 PM
