post pic of your van
#542
Here is a warning for all with a hightop, my Chevy rotted out due to a busted seal, pull that plastic lacing from it and check every screw, don't wait for them to back out, they will eventually come out, you can get new plastic to cover them up from an RV shop I think. Take off those aluminum running boards and treat the area they bolt to, everything I've ever seen with them has rusted out, it's best to toss them out all together. Nice van tho, for fun, look to see if you can swap the I-beams with the TTB.
#545
#546
My 1982 ford swb E150 and my 1990 E150 project...
Love short Fords I have a few in the past and saved the 1990 from the crusher in Alamogordo NM. Almost on the road after lots of service. Trying to clean up old gm orange coolant sludge now.....
Saved from crusher in Alamogordo NM. On road very soon. 300 6 cyl w C6 AT AC loaded.
This van had Appliance Wheels w actual oak centers on top of a steel spoke wheel.
#549
Yep, dex-cool that GM uses turns to pudding when mixed with the green coolant, which is why GM vehicles can't be converted to the green stuff, you can never fully flush out coolant. Everytime you take your vehicle in for an oil change, you are at risk of the shop putting in the wrong coolant, and there is no universal stuff, it's one or the other.
#551
#553
We quit after an hour, and it wasn't the sludge that you get mixing the GM and Ford coolant, it creates pudding, still don't see how you can get it all, which is why I cringe at the thought of discount oil changes.
My E350 is near impossible to get all the coolant out of it, it's due a change of the 3 year green stuff, not looking forward to it, should buy 50' of coolant hose and replace the rear, it's scabbed pieces on metal and rubber where the hold down mounts rusted the factory tin, shame on them not using stainless steel.
#554
a day with water won't kill your engine
after 3-4 times, it's all gone
#555
