post pic of your van
#198
Yes when install wheels and flares i was surprise they like one inch each inside of rear fenders and it was looking so bad and i can see and feel so much different handling also i install kyb monomax shocks and they are great, overall van feels nice and tight on road and hard, turns so much better
#199
#201
I gutted mine, built a deck in the rear with a subwoofer system, have a wheelchair lift, put bags inside the front coils, aired to 25 psi, to counter the leaning effect caused by the lift, I hang corners in my 15 passenger, stock rear wheel arrangement, so hard I have to hold myself up on the armrests, it doesn't even feel like it's gonna tip. One day I may replace the old factory shocks, I keep my tires aired to 80 psi due to keeping the wear on the front even, this 99 has yet to feel unstable, but 45,000 miles are all you can get on a set of HWY Coopers, on an 8000 lbs van.
#202
#203
Mine are bags that go inside the front coil springs, air lift, I want a pair for my 73, but they don't make them, so I have to measure to match a pair for it, they are great, but sacrifice the ride, made it stiff, and varies with the pressure. I found a pressure I was comfortable with, let it settle a month, then took it for an alignment, to correct the camber, it's important to keep the same psi or the tires will wear due to the camber changing.
#204
#208
Originally Posted by Cobra-Kai;
I'll post pics when the exterior is done
I'm not really satisfied with the paint, cause the clear coat was running away in a number of areas.
And the filler is shining through in the back, cause the black layer was sprayed to thin.
So that's why there are so many stickers on the right rear door - better than what's underneath it
But if i think about it i can be happy with it because:
- I paintet it outside instead of a dust-free room
- Parts of it i painted in darkness -> in one hand the spraygun, in the other a lamp
- It was hard for me to reach the roof - always ladder up, ladder down
#209
#210
