Sponsored by: Real Truck
Another ejected drink trying again
Old Aug 20, 2011 | 12:18 PM
Anomic's Avatar
Anomic
I looke previousky and couldnt find a solution. My '10 xl option package left me with only the teo shallow drink holders in the fold down armrest in the bench seat. I have the upfiter switches which i believe is where the cupholders normaly would be. I have two blank panels on dash; lower right (where aux input would be, and middle left above ciggarete lighter which i think is the one where the tbc would go.
I woukd mount it one the hump on the floor but there is a gearshifter there!
Im to the point i dont care and will drill on the dash but all i see online are really cheap holders made for atv/golf carts.
Any ideas on retrofiting an oem holders or an aftermarket solution. Parts numbers?
Also can the map door pockets be added on my truck doesnt have them either
Old Aug 20, 2011 | 01:14 PM
MDSuperDuty's Avatar
MDSuperDuty
My truck doesnt have the cupholders on the lower dash because of the manual shift 4x4 as I have the TBC and Up Fitters. I'd like to find a solution too and sorry I dont have one for you.
Old Aug 20, 2011 | 01:24 PM
I.B. Washincars's Avatar
I.B. Washincars
I have TBC, upfitters, and the cup holders, but I have ESOF. I would think if you ordered a cup holder for an XLT equipped like mine it would fit, but may have interference issues at times.
Old Aug 20, 2011 | 01:26 PM
MDSuperDuty
That is the issue. The manual 4x4 shifter is in the way of the cup holder.
Old Aug 20, 2011 | 01:32 PM
I.B. Washincars
I thought maybe it would only be an issue when in 4WD, but I guess that's not the case.
Old Aug 20, 2011 | 01:36 PM
Anomic's Avatar
Anomic
Ihave hAve two sticks the 4x4 and transmission which precludes mounting anything low as the shifters need alot of space down there. If i can find someithng decent quality that i could just screwinto the dash i will.
Take a pic of the cupholder you have it might work
Old Aug 20, 2011 | 01:54 PM
kd0axs's Avatar
kd0axs
How about one of those consoles that sits on the bench seat? I know you have the flip down console but you could leave it up and then use the console that goes on the seat.
Old Aug 20, 2011 | 03:41 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
how about removing the middle seat and dropping in a used center console or just and aftermarket one.....i know you can find them on ebay or junk yard
Old Aug 20, 2011 | 04:01 PM
Anomic's Avatar
Anomic
I thought about that but even the flip down is annoying i have to hold my arm up to avoid hitting it eith my elbow when shifting. I ride with it up akways except when using the drink ejectors
Old Aug 20, 2011 | 04:11 PM
jc8825's Avatar
jc8825
Hey Anomic, at least you have manual everything. I wanted a truck like that, but when you buy in the used market you have to get what's out there and there are very few XL-all manual trucks. I did a search for 08-10 (I like that body style) XL 4x4 all manual and only found 4 in the entire nation. No cup holders wouldn't be much of an issue for me, but I can see how the console ejecting them would be a problem. I think if you got a hold of some door panels from an XLT, you could remove the map pockets (on my 02 they are just kind of glued/melted onto the door panel using tabs and holes) and connect them to your non-power door panels with a little work. I would also say that unless you need that middle seat, swap in a center console. TreySpooner ordered the 08-up console and installed it in his 02 replacing the center seat.
Old Aug 20, 2011 | 07:43 PM
Anomic's Avatar
Anomic
Ya i found mine over 500miles away. Only option i really wnted was the 4.10s but the truck was almost exactly what i wanted. I wasnt ready to buy but the 11s new motors, no manual trans, higher price tag, and i didnt like the looks as much. It was hard to find a leftover 10 but the rebates where awesome and like i said other than color and the 4.10 option it was exactly as i wanted
Old Aug 20, 2011 | 08:01 PM
donjamer's Avatar
donjamer
I am not sure why your trucks don't have the in dash cup holders..
My 06 with manual tranny and 4x4 does.. Doesn't even come close to hitting
I also have 2 on the center console..
Maybe you need to find a dash out of an 06
Here's a picture of mine..
Old Aug 20, 2011 | 08:11 PM
redford's Avatar
redford
FTE Leadership Emeritus
I have manual hubs and transfer case and in dash cup holders plus the console cup holders, so I do not think ESOF is the difference.
Old Aug 20, 2011 | 08:25 PM
Anomic's Avatar
Anomic
Don jammer
That dash on the 06 is completely different from the 08-10. Im pretty sure the upfitter switches take the place of the cupholders
Old Aug 20, 2011 | 09:41 PM
SUPERDUTY_08
Originally Posted by Anomic
Don jammer
you are wrong. the cup holders on the 08-10 are below the upfitter switches. they fold out of the dash. On a truck with manual 4x4 this area is a solid panel. there would be no was to add these unless you replace that part of the dash. check out this pic in the link and you will see. Ford F-350 Super Duty wallpaper # 08 of 21, Interior, MY 2008, 800x600
