61-66, 73-9 parts f/s
#391
Category: Exterior - Body Parts
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, Prelude
Engine: Part suitable for gas truck
#395
Lascar... Quit hijacking threads... Major no no on here...
As to parts... All of the big stuff is gone... I have one tailgate for 80-86 I believe Flareside bed... Super nice original shape.
I only have RH armrests
I do have a few original door pouch trim rings...
No 65-66 sill plates, only 1 61-4 curved type left
I have a 65-66 upper valance as well as lower
I do have a 65 NOS bright grille... NOT CHEAP as its all but impossible to find... Its in the original box still
I have some inside door trim, no sets, lots of their clips though
Lots of fasteners... Mostly in cab or molding related
I have 292 Heater hose nipples
I have a couple original metal fuel and vacuum advance lines for 352
No rear end parts except brake drum screws for 3/4 ton and some axle seats that sit inside the shaft and are countersunk.
I have 1. 66 1/2 front brake drum
A few emblems/fender badge including a 65 F250 set for Ranger.
63-4 outside moldings... A left side wrong bed type one as well as door and hood as well as hood side emblems... No inserts
6 and V8 hood badge
Turn signal switch
57-60... Front end same as prior... Chrome grille and alum lower and core support and front painted bumper. A few dash ***** and vent cables as well... White *****
1 t/light lense.. For a driver...1 t/gate hinge too
Nothing for 67-72 except emblems... Including some 67 ones
Also have rear reflectors too. I have a horn ring as well in great cond.
73-9... Left fender trim with rub strips...1 right too
Ialso have a set of the load tie downs
Grille halves
I also have the dash insert trim for Indy Pace truck... Bezels gone or bad.. Its a glue in piece... Great orangish red color. Stainless door mirrors... Low swing arms too
More later, cs65
6 and V8 hood badge
Turn signal switch
Grille halves
More later, cs65
#398
63 Ford Unibody parts needed
I am looking for a radio, steering wheel, Hood, rubber heater duct [kick panel to heater], western mirrors and brackets and a 61-66 big Ford truck accessory light switch [mounts in dash like other switches]. In addition a chrome/white instrument cluster panel [Round speedo]
#401
Would be interested in radios if you still have? How much how many? *****?
Bill homeatlast43@yahoo.com
