1999 F-350 Diesel engine shutting off
Hoping this might make sense to someone, and we can get this fixed.
Three times now when pulling a load (9000#) and the rpm gets under 1000, and you just take your foot of the gas peddle, the engine will just shut off. You can put it in neutral, or stop and park and restart OK. After the first two times we took it to the dealer, and they did the following. It happened for a third time though, so obviously the problem still exists. Here is what is on the dealer invoice.
EBP sensor out of range. possible source at fault. RECC EBP connector and readvise.
1. Replace EBP and connector. Replace and retst EBP and Retests in range . OK
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Why would it shut the truck off? You can run these trucks with the eb sensor unplugged as well as the ebpv and not have issues with the truck shutting off. You could easily unplug them both and if the truck still dies while driving down the road I'd look somewhere else. Cps has my vote as well!
jorda23
10-03-2006 09:00 AM
jls73
16
04-01-2005 12:52 PM
