Worst Modern Day Truck Engines (What do you think?)
I had a 2.7 l engine in a 1977 Mustang (yes the old Mustang II - exwife loved it). I had a similar 2.8l v6 in a 84 Ranger - died at 70000 miles. These were European built Ford engines. Leaked oil profusely. Did get just ok MPG's. I think the new Explorers still use this.
got a 91 explorer 4.0L getting close to 300,000 miles, finally starting to use some oil and antifreeze, but at -35 it still starts with the first cylinder past TDC. even after sitting for a month. def never was much for high end power but surprisingly torquey. other than a clutch and rad pretty maintenance free
I gotta ask the OP, why all the hate one the old engines that made the F-Series? My '92 with a worn-out 302 gets comparable mileage to a 5.4 and probably the new 5.0. I'll admit it's lacking on power, but a rebuild and a better cam will fix that for the most part. I'd never trade my old, simple, user-serviceable engine that has half the wires and sensors the newer engines have for a 5.4 0r a new 5.0. The old engines can take more abuse and are time proven designs. Most of the trucks they came in can take more abuse than the new ones too.
I actually rank the 4.6L 2V right along side the 300 I-6 as one of Ford's best ever produced engines.
Is a spark plug issue real cause to call an engine bad? Yes, it can get frustrating and be expensive to repair but the engine itself is well known to run for over 250K. Most modern diesels only run that distance before major service is required. I consider both mod motors to be a score on Ford's part.
Perhaps the scope of this topic should have been given some guidance such as:
1. Overall reliability
2. Cost of ownership, daily driving and maintenance.
3. Parts availability,etc.
The 351 and 460 were fantastic for the first 100K to 150K then they required plenty of work. This is only my personal experience and not industry fact.
Then again, one only needs to look in the 6.2L and Superduty forums to get a glimpse of the issues that are happening with Ford's newest big V-8. I won't get into that here but if anyone is interested.....
luvmyf1502.7crew
2015 - 2020 F150
02-23-2018 02:34 PM
640 CI Aluminum FORD
2009 - 2014 F150
35
08-22-2010 09:13 PM
lowtrkn2k
104
10-24-2007 08:52 AM
