Light ????
Old Aug 18, 2011 | 11:26 PM
SuperDuty93's Avatar
SuperDuty93
Light ????
I know ive asked b4, i think i know what headlight i want to replace mine now but not sure.
The ones that are on the truck now i just discovered do as much as the blinker. My interior lights are brighter.lol I need a modern style headlight that i can put in brighter bulbs if need be.
Any suggestions?
Wana keep the price down also. No HID!
Old Aug 18, 2011 | 11:53 PM
wyckedcombo17's Avatar
wyckedcombo17
There was a thread on this recently. I think someone used sylvania's? You should update your wiring harness too...
Old Aug 19, 2011 | 06:48 AM
pidaster's Avatar
pidaster
Update your headlight wiring harness if you want them brighter. A new, high power bulb won't do any better on limited voltage.
Old Aug 19, 2011 | 07:32 AM
fmc400's Avatar
fmc400
MSEE
I do agree that the relay upgrade is an effective way to get brighter headlights - but the stock lights shouldn't be dimmer than your interior lights. You might want to inspect the wiring pigtails for corrosion, as a first step.
Old Aug 19, 2011 | 11:34 AM
i-w's Avatar
i-w
Also make sure the alternator brackets that mount it to the block are clean.
all the points where the brackets contact the alt and engine block. The alt
grounds through that to the block. Also check the negative battery cable
for good clean contact to ground. they need a good cleaning once and a
while.
Old Aug 19, 2011 | 11:12 PM
SuperDuty93
Im going to redo the wires but still want the new look....
Anyone know anything or can tell me the difference between these four?
1974 Ford F250 Headlights
Old Aug 20, 2011 | 12:11 AM
HIO Silver's Avatar
HIO Silver
Well yeah.
Sealed beam
Sealed beam with halo
Sealed beam projector with city light
Sealed beam projector with city light and halo
'strange that they call them "sealed beams" because they use a replaceable bulb. Sealed beams are, well, sealed in a vacuum like an incandescent bulb.
A "city light" is an accessory bulb inside the housing and below the main bulb. It is a low Watt bulb wired to the parking light circuit. Some cities in Europe don't allow the use of headlights within the city limit cuz the streets are already lit up. Hence, "city lights".
The other difference is the projection. The first two use a bulb reflector (cover) while the projectors use a lense over the bulb to disperse the light.
PS.. your light rack is ready. I'm having a tuff time finding a 5-foot long cardboard box. I may have to go to a flooring store to find a carpet tube.
Old Aug 20, 2011 | 05:39 PM
SuperDuty93
Originally Posted by HIO Silver
Well yeah.
Sealed beam
So i guess i want #1 or #3, i think the others are to modern. Now #3, will the center circle light up as well as the bigger outer circle?
Old Aug 20, 2011 | 06:20 PM
SuperDuty93
I decided to go with #1. It will look better when turned off i think....
Nxt question is what bulbs to install in them? We have PIAA's in our other trucks but i dont think they are that bright.
Here is a link to the H4 bulbs by PIAA, what one is the brightest?
PIAA
Also, is there any other good bulbs beside HID that are SUPER BRIGHT! ?
Old Aug 20, 2011 | 09:53 PM
HIO Silver's Avatar
HIO Silver
Jeez Louise..... If ya click on the image, you'd see the note that says they come with H4 bulbs. Why don't you wait until it's installed and evaluate the light output at that time?
Old Aug 20, 2011 | 10:37 PM
rmodel65's Avatar
rmodel65
if you have round head ligths you can get LED lights you can find the lights cheaper in other places...
Mustang Project - Product Display
heres some for 300$ http://www.bjsoffroad.com/CartGenie/prod-1062.htm way way brighter and pulls way less amperage....
Old Aug 20, 2011 | 11:14 PM
HIO Silver's Avatar
HIO Silver
heres some for 300$ View the 7-inch Round LED Headlamp by Truck-Lite 27250C at http://www.bjsoffroad.com way way brighter and pulls way less amperage....
IMO, not a very good value for $620 a pair. Even at $300 it's not worth it... that is unless ya just wanna flaunt your wallet or are doing it for show. Spend ur money where it counts... suspension, engine, brakes...
Old Aug 20, 2011 | 11:17 PM
rmodel65's Avatar
rmodel65
depends on how much you value being able to see when driving at night
Old Aug 20, 2011 | 11:59 PM
SuperDuty93
HAHAHAA! I always plan way ahead so when it comes to that step, im on it!
Old Dec 29, 2011 | 05:29 PM
Buck0's Avatar
Buck0
I am very interested in how this turned out as I am looking at doing the same thing. SuperDuty93 can you please let us know if these turned out to be quality parts? And I think you were going with the 1st choice on the page, is that what you ended up getting? How do you like them? Thanks.
