OFF TOPIC – I need some shop advice?
I’m doing sound deadener and insulation, the shinny tin foil stuff, because I have always wanted to, (pictures available upon request) and I got a small roll of aluminum foil tape (used in heating and a/c I think) to cover the seams (and where I screwed up) and with my bad old eyes and fat thumbs I spend more time trying to find an edge and separate the backing from the foil tape them then I do working, ………………..does anyone know of a technique or magic trick on how to find the edge to pull them apart?
Thanks,
(oh, put new speakers on the shop satellite radio and the blues sure sound good now)
Thanks,
You can try a couple of ways to remove the tape from the backing. First try tearing it with your fingers which will leave an uneven edge with the backing or tape exposed. If that doesn't work, try sticking a piece of masking tape (not the blue type) on each side and use that to pull the tape from the backing.
Gil
Gil
Received 4,131 Likes
on
That's the same insulation and tape I have on my garage. I'm not sure if it's possible, but maybe you could start one end of the tape about 6 inches and then pull the paper from the foil as you press the tape on. When you get to the end, rip only the foil and not the paper. Then you'll have a paper tail to pull the foil from for the next go.
You guys are the best, thanks for the ideas / suggestions. Sometimes it’s the little things that frustrate the heck out of me.
Now that seems like a simple question. Not so on the answer, my last project was noisy and hot so I am making every effort to make this one is cool and quiet.
The cab inside was completely painted then the floor inside and out, the firewall inside, and the back wall where coated with home made Lizard Skin (box liner and fiberglass Microspheres mix) then the cab floor, firewall and back wall, roof (to be done) where coated with two layers of rubber roofing material (ice barrier) left over from the last project. The roofing on the floor (that reads funny) was then covered with an EVA sound deadener kit off eBay and that was covered with the foil cotton waste insulation (very hard to cut) and then Classic Haulers carpet kit.
The inside of the firewall has the roofing material on the Lizard Skin then Dynamat (engine heat and sound) and then insulation (bubble type under the dash, much lighter) back wall much the same and headliner to do. Over 12 cans of two types of spray glue so far and upholstery to glue yet. ****……. but should be cool and quiet, huh?
Jag Red 54
49
01-16-2007 07:52 PM
