1960 f100 Radiator Question - Ford Truck Enthusiasts Forums
Old 08-17-2011, 08:41 PM
rnelson664
rnelson664 is offline
rnelson664 is starting off with a positive reputation.
Running a Ford crate motor, 351w, rated at 385 hp mounted to a c4 tranny. I'm also running air conditioning. Will the stock radiator be able to handle this set up or should I be looking at buying a different radiator. If you think I should upgrade any suggestions would be appreciated.
Thanks,
Ray
Old 08-17-2011, 09:08 PM
60 F100 4X4
60 F100 4X4 is offline
60 F100 4X4 is starting off with a positive reputation.
I have the same dilemma going on minus the air conditioning, I have the same model year and same motor trans combo going in. What I have ordered is a separate trans cooler with an electric fan that I will be mounting to the rear of the trans via the frame, alot of guys out here in Las Vegas that I have talked too that wheel on the weekends tell me they have had no problems doing it this way after having problems trying to run a higher HP motor off of the factory radiator. I decided not to take the risk so this is the route I'm taking, as for personal experience I have none so take it with a grain of salt.
Old 08-19-2011, 12:57 PM
mcdonaldm
mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
i would be looking at running a different rad for sure with that combo. you probably have a bit of money into the engine, so why cook it by using the stock rad. lots of aftermarket rads out there that will custom make a rad to fit for you. Griffen is one that comes to mind and in the long run they are not that expensive considering the cost to rebuild or replace a overheated motor.
definately go for an aftermarket alum rad with that combo. i wouldn't trust the factory rad as they were designed for a lot smaller engine with a lot less hp then what you have currently.
rgds
Mike
Gotanoldtruck
01-02-2015 10:31 AM
1976 Highboy Ranger
09-28-2014 09:01 PM
BigBlueCat
05-25-2014 03:16 PM
Jumbo131
6.7L Power Stroke Diesel
03-25-2014 08:46 PM
linckeil
09-13-2009 12:02 AM
Quick Reply: 1960 f100 Radiator Question
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
