Truck Won't Start, Turns Over, Bad Fuel Pump? Air? - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
  #31
Old 08-18-2011, 09:53 PM
supperman2k
supperman2k is offline
supperman2k is starting off with a positive reputation.
FICM Sync
and CMP AND CKP are in sync both read 0. confirmed.
I am not sure what that means but i just checked and I got another code
P2614 Camshaft position output circuit / open
is this just from cranking to much? this did read earlier as well.
  #32
Old 08-18-2011, 10:12 PM
supperman2k
I just did the injector test and it seems fine on my AE tool. no errors
I heard the buzz when it performed the test on all injectors.
  #33
Old 08-18-2011, 10:23 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
p2614 make shure its plugged in fulley
heres the code def
P2614 C O R Camshaft Position Output Circuit CMPO signal intermittent Poor connection, electrical noise. In CMPO from PCM
those cam and crank sensors dont go bad to often
maybe those mice chewed the harness
does 0 for sync on AE mean there in sync
  #34
Old 08-18-2011, 11:12 PM
supperman2k
I heard 1 means red and its bad.
I believe 0 is fine.. I will make a post about it separately and see if I can get a spark up a conversation regarding this feature of the AE tool.
  #35
Old 08-19-2011, 01:34 AM
bismic's Avatar
bismic
bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I thought it was the other way around ......
  #36
Old 08-19-2011, 10:35 PM
supperman2k
Problem solved,
AT KOEO truck will show CMP AND CKP in sync at 0, and FICM Sync as well at 0.
Both should read 1 while cranking and running.
I adjusted my wire harness, and heavilly adjusted the CMP sensor wire, and truck fired up right away.
I know have an intermittant CMP and CKP Sync going 0,1,0,1,0,1 etc..
  #37
Old 08-19-2011, 10:51 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Originally Posted by supperman2k View Post
Problem solved,
thats how I take it to 0 at KOEO and during crank or running you want 1
I wasnt shure on AE thanks for clearing that up for me
I know mine reads a solid 1 for cmp/ckp while running
you might need a new harness for that
but atleast you know what needs to happen
Polkster
03-01-2014 02:26 PM
Opossum
09-24-2012 03:55 PM
marc21387
06-18-2012 11:15 AM
unseenthings
05-09-2006 04:35 PM
BoostLover
11-28-2003 11:59 PM
Quick Reply: Truck Won't Start, Turns Over, Bad Fuel Pump? Air?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
