2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
heated seat
Old 02-10-2012, 08:22 AM
jozan's Avatar
jozan
jozan is offline
heated seat
if i replace the module for the heated seats will it need to be programed or is it plug and play
Old 02-10-2012, 06:04 PM
cop on my back's Avatar
cop on my back
cop on my back is offline
If you are talking the actual heater/cooler fan unit under the seat or the back, they are plug and play. I know because I have a bad one in my ride as determined from the dealer. The dealer confirmed it is a plug and play so I just have to buy a new one and install. The unit in the seat back can be replace without removing the seat.
Old 02-10-2012, 06:21 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
According to the service manual........Yes.
Dual Climate Controlled Seat Module (DCSM)
Removal and Installation
WARNING: Never probe the electrical connectors on safety belt buckle/retractor pretensioners or adaptive load limiting retractors. Failure to follow this instruction may result in the accidental deployment of the safety belt pretensioners or adaptive load limiting retractors, which increases the risk of serious personal injury or death.
NOTE: The air bag warning indicator illuminates when the restraints control module (RCM) fuse is removed and the ignition switch is ON. This is normal operation and does not indicate a supplemental restraint system (SRS) fault.
NOTE: The SRS must be fully operational and free of faults before releasing the vehicle to the customer.
1.When installing a new dual climate controlled seat module (DCSM), carry out the appropriate steps in the programmable module installation (PMI) procedure. For additional information, refer to Section 418-01.
2.Position the front passenger seat fully upward and depower the SRS. For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in the General Procedures portion of Section 501-20B.
3. CAUTION: Do not pull from the inboard side of the front seat cushion panel shield to avoid damaging it.
Remove the front seat cushion panel shield.
•Release the upper retaining clips working from the outboard side and then release the lower retaining clips.
4.Release the 2 tabs and slide out the DCSM.
5.Remove the DCSM.
•Cut and remove the wiring harness tie strap.
•Release the 2 locking wedges.
•Disconnect the 3 electrical connectors.
6.To install, reverse the removal procedure.
7.Repower the SRS. For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in the General Procedures portion of Section 501-20B.
8.If a new DCSM has been installed, carry out the appropriate steps in the PMI procedure. For additional information, refer to Section 418-01.
Matt
Old 02-10-2012, 10:28 PM
jozan's Avatar
jozan
jozan is offline
thanks for the info, where did you find that
Old 02-11-2012, 08:38 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
I know a guy, who knows a guy, who cousin's friend's sister's brother's uncle's father who ............
Just kidding I got it from the Ford Factory Service Manual.
You can buy then online as a CD or as actual books. Very helpful stuff even for the backyard mechanic.
Matt
Jeff2005LariatSCAB
2004 - 2008 F150
03-07-2019 08:58 AM
clifish
2011 to 2019 Explorer
10-08-2016 04:03 PM
NorthGuy0
2009 - 2014 F150
08-11-2016 08:58 PM
jpjennings
1999 to 2016 Super Duty
05-27-2015 10:10 AM
encorick
1997-2006 Expedition & Navigator
11-21-2003 11:24 PM
Quick Reply: heated seat
