hard to start after an hour
1979 f250 400 engine. Starts in morning great runs great. If turn off after running and wait a minute or so will start great. If i wait an hour or more i have to crank and crank to get going. but in morning will start great again.
there is a spark at coil while cranking
there is fuel in fuel filter but cant see sprays in carb when cranking while pumping accelerator
NEW- fuel filter&hoses , plugs ,wires, rotor, dist. cap, coil, rebulilt carb last spring,new electronic ignition box april
Fuel pump??? but why start well every morning?
Hot start problems are usually fuel related, when a hot engine is shut off the temperature of the engine and everything on it continues to rise for awhile as the engine undergoes a period of heat soak, this can cause fuel to boil inside the carburetor bowl, fuel lines and fuel filter, when you attempt to restart the engine vapor lock obstructs the flow of fuel and the engine doesn't want to start, installing a phenolic spacer between carb and intake will help alleviate this situation.
'had a similar problem with my 65 Mustang. After the initial operation, which was fine, stopping the engine caused a real difficult start after 15 minutes or so. After letting it sit for more than a few hours, then it could be restarted like normal.
'Turned out the accelerator pump had a small leak causing fuel to be drained from the bowl and down the intake manifold which, in turn, caused a flooded mixture. Only cranking and cranking would restart it... I however felt that was not receiving fuel and my right foot only exascerbated the problem. A quickie rebuild of the carb solved the issue.
Heat soak/vapor lock could also be the culprit but I'd check that carb.. especially if the rig isn't used very often or if it hasn't been rebuilt for a looooong time.
thanks I went out and took off air cleaner cover and depressed throttle and could hear and smell gas spraying into carb
i then cranked and cranked i also pumped the petal and it finally started seemed little flooded little black smoke came out of exhaust
also if it matters i started it today once by rolling down a little hill and letting clutch out
Because by the AM the fuel that leaked out of the bowl and down the intake has already evaporated.
Also good to check the starting system. Use a voltmeter on the battery on startup: Check voltage before, and during cranking, should only be about a 2 volt difference. Could be bad ground, connection, starter or battery.
The bigger V8's do have heat soakdowns and are harder to start after running.
The accelerator pump is not responsible for starting the engine cold; this is the choke's job. When you press the gas pedal once in the morning to start the truck, you're freeing the fast idle linkage which lets the choke snap shut. This is what helps the truck start cold, not an extra "shot" of gas (common misconception).
LittleBlue79
21
05-25-2018 02:50 PM
chrischasejordan
05-29-2012 08:47 PM
cowgirl_truckin
Electrical Systems/Wiring
06-23-2003 12:55 AM
cferrari
04-07-2003 05:22 PM
