pin pad key code pad idk 04 f250 resetting or finding code.
i bought this 04 f250 its on the tow truck from az... i found a list of like 100000 digits but its from the excursion section dont know if it will work... where can i find the code? and also i was told you could turn the ignition plastic thing with out the key in it? wtf how do i fix this? thanks guys
you need a new ignition tumbler if it will turn without a key. make sure to get the doors rekeyed by a locksmith if you replace it. otherwise you'll need to carry 2 keys. 1 to get in, 1 to start it
for the keypad code, I just did this last week. Open the small glovebox under the steering wheel. lay on your back and look up into the dash. On the firewall directly underneath the radio you will see a black or grey module. It will have a white sticker on it. You will see a 5 digit code printed on there.
that code is the factory code. you can use that, or follow the directions in the owners manual and input your own personal 5 digit code
No drivers side glove box on an 04. Read this thread for instructions on finding the code for 99-04 trucks.
https://www.ford-trucks.com/forums/5...ypad-code.html
Gentlemen,
I have recently purchased an 07 F350 4x4 Crew with the 6.0 stroker. I have noticed that when in low, first taking off and pulling a hill that the transmission shudders. Once speed is increased the shuddering stops. What could the cause be and is this something I should be concerned with?
Now in regards to the pin pad resetting. Is the security module under the radio on an 07 as well?
Gentlemen,
Your door code is in the same place, but on your 07 you can just open up the drivers side glove box and look up in there with a flashlight. You should be able to see it.
