Cost of ownership: '99+ F-250 w/ PS vs '04+ F-150 w/5.4
I realize that comparing a 1/2 ton to a 3/4 ton is like comparing apples to oranges, but I would like to hear what people have to say. How does the cost of ownership/maintenance for a F-250 with a PS compare to a F-150 with a 5.4L?
My driving factor for wanting a PS is that any truck I'm going to get is likely going to have 100k+ miles (less for a F-150). I think I'd be better off getting a PS with 100k+ than a 5.4 with 80k+. I've seen plenty of 5.4L trucks for sale with rebuilt engines and less than 150k miles. With a PS, I should be good well beyond 250k.
I'm capable of doing much of the maintenance/repairs myself, however my time tends to be limited. I often wind up having to just drop my vehicles off at a garage to get worked on. I do have a second vehicle though, so if something breaks on the truck, I can get to it when I get to it.
Looking around online at parts, they don't seem to be too outrageous...even the aftermarket stuff. I'm coming from a '97 Toyota Land Cruiser though . I would be hard pressed to find something that's more expensive to maintain. I would appreciate any insight that you can offer.
Well the first question you need to answer is what are you going to do with the truck? Are you going be hauling stuff or it is more of a daily driver?
If it is just going to be a daily driver I would go with the F150, honestly a diesel can be very expensive. It requires 4 times the oil, which costs more per gallon anyways, it burns a more expensive fuel, and most ppl's mpg difference isn't enough to cover the added maintenance and upfront costs of the diesel. Everything is more expensive on a diesel for the most part.
If you have a specific need for a larger truck, such as snow plowing and heavier trailer towing, then the 7.3 is a good option.
I have no personal experience with the 5.4, though I do have a family friend that 305k on one. I put 207k on a 351 in a bronco that had a 7.5 foot western plow hanging off it every winter. My father put 257k on the 302 in his 1986 F-150 and my mother has put 145k on a 302 in her mounty...none had any engine issues. So Ford small blocks have a good reputation for longevity if properly maintained.
Food for thought:
Home
Food for thought:
Home
Food for thought:
Home
Food for thought:
Home
Yeah...that's the main drawback that I was already considering. At the end of the day...If I go with this option, it would be because like every other office dweller that has one...I just want a diesel.
I've heard good things about the older 300 and 302. I was originally considering picking up a late 80's-early 90's F-150 for a beater. If I decide to go the 1/2 ton route, I may just do that. There's not much of a point (to me) to spend $10k+ on a half ton when I can get something for one fifth the price that will do what I need it to.
Thank you. Your comments are right along the lines of what I was thinking.
Edit: Yeah...my parents had a '98 Expedition with the 5.4. They put about 110k on it. It went through brakes quickly, but it never had a mechanical issue.
Based on what your really going to use the truck for...get a gasser, even if the motor blows their dirt cheap to buy reman'd or rebuild versus the diesel...Now if their is that little part of you that just wants the awesome clacky 7.3, thats cool too and i don't blame ya , maitenance costs are 2x plus the 5.4 and a little wrenching here and there is necessary...I personally don't use my truck for work as much anymore as my business grew but I am a car nut and I just love the 7.3....something just special about hearing that beast come to life every morning
My coworker has an 05 F150 5.4. At 50k he put a few grand in it doing cam phasers, and all the timing chain related wear parts. He's getting 15mpg at best and now at 130k its due for the same repairs. $2100 was his cheapest estimate. He considered a replacment. Engine but 3 of the last 4 places won't touch a 5.4 because of cam phaser warrenty issues.
He's been anti diesel since we met, and he's currently shopping for a diesel...
Just my .02
Just my .02
Those early 3V 5.4L modular engines had terrible problems with the spark plugs breaking off in the heads.
You'll have to do some research, but IIRC, even if you take it to the dealer to have them changed, they won't cover the expense of having them removed if their tech breaks them off. And from what I understand, it's almost a given that at least one of them will.
Stewart
Stewart
Part of me really does want the clickity clack of a diesel. I had a diesel MB sedan for a while and I thought that thing sounded cool as hell. It had 291k on it before the engine seized up and I got rid of it. No idea what was wrong with it. As I pretty much got it for free, I was unwilling to spend $,$$$ to have it repaired.
Just my .02
Just my .02
Stewart
Stewart
I had a 97 F150 that I bought new. 4.6 auto 4x4 Ext . I put 180,000 miles on it.
Replaced the starter, Alt, spark Plugs and wires. Also had the wiper actuator arms replaced.
That was all I had done except for routine maintenance. My 7.3 has already cost me more than that, but I had to have a bigger truck to haul my 5ver. I have put 40,000 of 160,000 that the 7.3 has on it. Just my .02
My friend has a 02 expedition 4x4 w 5.4 150 thousand miles and gets 12 mpg till it blew #7 plug out (first time I got to tow with my superduty) it's in the shop now, $2000 for a new head or drill and tap a new plug hole for $500-700! Called three dealers and said it's somewhat common, they have all done it before. My 97 2wd 100000 got 19mpg till now getting misfire on #7 I'm afraid to look at it hope just a bad coil. Dealer says to pull sparkplugs out every oil change! Aluminum heads and the deep hole the plugs are down in don't go good together with corrotion.
Another thing is if you use the 7.3 in a "commuter" fashion versus a towing rig it's going to give less problems too just because of the lack of stress on the truck (some stupid electronics like a cps are unavoidable). If i were you, I would search for an original owner (maybe 2..) very well kept 7.3, you would be surprised the difference in one used for heavy work versus a commuter...I've seen big differences in some of my trucks i've bought for the business. The 2 vans I got from the guy who bought them new to haul computer equipment to upstate NY every week had high miles but ran and performed flawlessly...one now has over 320K and runs like it's new still.
I've got an uncle with a '98 F-150 that has the six banger. It's got 180k miles and doesn't sound great...but it hasn't stranded him.
