Transmission cooler ? Hayden VS True Cool
Hey Guys i have a 1995 f150 with a 5.8 and an E4OD. The truck is stock for now but im planning on using it for a welding truck/ tow rig to pull my jeep or motorcycles around. I am in the middle of swaping out the tranny because the rear planitaries went out. I want to put a bigger tranny cooler in and im looking at the Hayden 516 or the True Cool (not sure model number) both are rated for Class A motorhomes pulling upto 10k LBS but im not sure which one would be the better selection. The hayden i can get for 60 the True Cool is $91. The reason im looking at these guys is because they are in stock and i can pick up right now.
A transmission cooler is a transmission cooler.... some have better fittings than others.
The Tru Cool must be a LPD.
I have a Torq-Flo Super Cool for class A motorhomes towing up to 10k lbs me to on my class C motorhome. It's 11"x11"x3/4" thick, and even that ain't that big.
As long as it's a stacked plate design, any will do!
10.5 X 7.5 X 2 inch 32 plate with expanded fins . I remember the area of it was over 157 N change. I spent a month looking for one that was equal to it. B&M had one for 200.00 but was too much for my blood. Ford had them for 130.00 IIRC. I put a older F350 unit on it out of L wards truck and its 1/3 the size... Pic looked the same so I took it @#%^$ Doh. 250-HD think mine was a cab and chassis also. I dont know if this changes what was on the other 250's from 95. Think wards was a 92, as I said way smaller?.!
yours is 90.75 so not twice as big but 90.75/ 157.5
For the record I don't think it really matters.... Just posted for facts, due to my search, for a replacement of the bleeder. My garage floor thanked me don't think the truck cares...
I'm clueless. I plan to add a new finned pan with a bung for a sensor/temp gauge in cab. Under 195 Im happy ... Till I do I have no idea how well the stock set up in my truck works.
Well, I'm not understanding this very well, but I think that every truck with an auto made after 92 has a tranny cooler that is part of the radiator(?) I think. the replacement radiators that LMC truck sells make this note and seem to indicate that it's integral to the radiator. So...does it even count?
