Goofed on A/C mod need advice
on
I was flushing my radiator and disconnected a hose from my ranger valve i use on the ac mod.I noticed when the air is on coolant flows through it when it is off it,or the heat is on nothing flows through it,what did I do wrong?It is an early 99 and i used the white vacuum line by the passenger foot area for the vacuum line.Any help is appreciated. John
Assuming this is the valve from Diesel-site,make sure that arrow on valve points toward water pump (forward)when installed on heater hose??
Locate white vacuum line under dash board under glove box. Remove the fitting from valve and install tee supplied.
Route new vacuum line thru dash board following path of old black line. Once in the engine area connect the line to the new control valve.
Like Pop's, it is only active in MAX.
I can scan and send if I have address???
on
thanks fo rthe replies,apologize for not getting back sooner work relocated me 125 miles away and the hurricane is stil causing headaches,anyway,I took some pics to show what i did hope they help,and the part I got the number from a link here at autozone,i believe it was 75409,its written down and I left it back home,if the pics need explaining just let me know,thanks to all
on
lionheart3
07-04-2010 10:03 AM
