Flushed coolant 3 times and still looks like iceT
on
I flused once with hose water and it stopped looking green,then twice with distilled water.Now when it drains it looks like ice T,maybe alittle more orange than brown.Should I use a flush chemical,more distillled water?Any advice is appreciated. John
Prestone make a great flush for the coolant system. Its a super flush for neglected cooling systens. In its directions it says to fill with water add additive drive frive for 3-6 hours or a doy or two then drain. I would recomd adding 2 bottles of the super flush drive it then drain system. Hopefully this will help. I'm with Steward don't refill with ELC unless its coming out clear.
Stewart
I didn't mean to botch your name Stewart. It was a typo on my phone my apologies brother. I main chioce for refilling with the green coolant was my wallet wouldn't let me change over. Lol. But it had to get done so I did this for now. I'm also glad I could give ya'll a chuckle at my exspense.
An easier way to flush well is to buy a Prestone or like brand flush and fill kit, put the "T" in a heater hose and run/flush until the water is completely clear, THEN MAY BE add some flush chemical & run as directed, then flush again with garden hose pressure, I do it to all my vehicles (used) when I get them, then service the cooling system with all new hoses, TStat and cap and I'm good to go!
I just had to replace injector cups- diesel in coolant. I took off radiator hoses and flushed radiator. Then pulled t-stat and flushed engine. Worked pretty well. i just ran garden hose through both for 5 min. Then I filled up with plain water and ran it up to temp and drained and refilled. I have done this several times now and it gets better each time. A word of caution doing this - I am having to replace water pump- I think it was already on its way out, but straight water is not as lubricating as coolant mix. Hope this helps.
I cut the center out of the old t-stat then re-installed with gasket. You don't have to wait for it to open. Easier re-fill and full circulation on start up.
To the Original Poster: Did you remove the block plugs when draining cooling system? Bottom of block cooling passages won't drain without removing the block plugs.
choate
09-30-2014 11:15 PM
powerstrokedieselfan
12-26-2010 11:44 AM
