Engine sizes
Old 03-08-2012, 04:22 PM
Glxy66's Avatar
Glxy66
Glxy66 is offline
Engine sizes
What V8 engine sizes were available in a 1964 F700/800. The engine has 5 bolts for the valve cover, but it looks a little big for a FE engine. Thanks for the help. By the way, it is gas.
Old 03-09-2012, 11:41 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,583 Likes on 1,291 Posts
With 5 bolts (the SDs have 8 or more if I'm seeing them correctly) it is an FT. The intake manifold should extend under the valve covers. If so, FT for sure. I take it you know the FE motor, here is a pic of the SD motor:
Redirect Notice
330, 361 and 391 were the sizes. The 330 was a small bore (3.8something, I can't recall) with a 3.50 stroke. 361 was same as a 360, 4.05 x 3.50 and the 391 was the same as a 390--4.05 x 3.78. The 361 and 391 were also designated 359 or 389 late in their runs. These were detuned (even more detuned) smog motors.
Why Ford would designate different CID's for the same bore and stroke motors (also done with the 352 FE, a 4 x 3.50 vs. the 351C, W & M, all 4 x 3.50 motors) is anyone's guess. As a famous motorist in LA said once, "Beats me!!!!"
divinusmonstrum
24
10-25-2012 08:58 AM
Customcab
23
12-02-2011 08:45 PM
larry69chevelle
11-08-2010 09:49 AM
LSEYMOUR
Texas Chapter
06-08-2006 09:44 PM
ladyrebecca
13
05-15-2004 09:30 PM
Quick Reply: Engine sizes
