53 rear window frame
Received 4,130 Likes
on
on
You should be able to make that patch, I'd clean off the paint to see where you have good metal. If you don't have access to a metal brake you can clamp your sheet metal to a bench with a piece of hardwood or piece of angle iron to make the bends you need. For the rounded bend use a pice of pipe or route the edge on the other side of your hardwood plank to the radius and form it with a hammer. Bondo covers a multitude of sins,lol. Someone might be willing to cut the piece for you from a parts truck but that patch could be made fairly easy. Seeing as you are working in this area you could also install a third brake light if you are deciding to go non-stock.
on
1 Post
Unless you know what you are looking for most people don't even notice the BBW...you know that something is different, you just can't figure out what. These changes are what I like the best...the in your face mods sometimes take away from the overall appearance of the truck.
