F250 front end sag
My local Ford guy gave me a similar price - directed me to a local spring shop with a good reputation - they quoted $295 a side for parts. A mechanic friend recommends JC Whitney, I've heard good things second hand about Jeff's Bronco Graveyard though I have no personal experience. I'd shop around online and check reviews.
What happens to the old springs?
Haven't decided where to get springs yet. But a friend of mine said Sacramento Spring in West Sac, CA does an excellent job of re-arching springs. All I have is a hydraulic jack and a couple jack stands, so I'm thinking I'll buy some replacement springs, have someone put them in, then have Sac Spring re-arch the old ones... if there's a market for them.
Thanks for the suggestions!
spring replacement not turning out so well --
I purchased replacement springs from National (code Q) OEM specs, no lift according to Ben at National. I had Ford put them on. Now I have a truck that can't be properly aligned because the damn thing is pigeon-toed (tires point in at the bottom and out at the top). What the heck is going on -- anybody know or have ideas? The tires look like this when looking from the front: \ /.
I called Ben at National and he verified the springs were the correct ones. Ben said to make sure the weight was on the springs before the bolts were tightened on the bushings. Ford said they did the installation by the book. So far, this is a 2K bad idea. Ford also had to replace the right and left top ball joints, they said.
Firefighter 1406
1999 to 2016 Super Duty
09-03-2010 08:51 AM
balderman
04-12-2009 09:31 PM
I_Thnk_Ford
02-28-2005 05:03 PM
77fordcrewcab
06-28-2004 07:23 PM
