96 F-150 truck Vibration Problem
Transmission mount bolts retightend will see if that fixed the vibration problem,
I will let you guys know if it worked.
Truck drives great, around 40mph to 70mph there is a vibration problem only at those speeds.
Checked the Driveshaft its tight.
Any other ideas what it could be?
86f150302? i thought i read that your bolts were loose and you retightend them and it fixed the problem?
Middle age regular maintenance begins !
My truck recently had a vibration issue...Pushed on the D/S, and got no play, drove the truck around, THEN rechecked...Had 1/4-1/2" of slop...Replaced the U-Joints and it drives as smoothely as silk...
As stated before, check the balance of the tires...Could very well be a busted belt...
Btw-Seeing as I am a self-declared grease ****....GREASE YOUR TRUCK OFTEN, if you have to think about the last time you greased it, IT NEEDS TO BE GREASED....
lol...Just had to throw that in there, and as seeing as it is a integral part of maintanence, and the life of your U-Joints.....be sure to spread the wealth to them...OFTEN...
I have the same problem and i just put new tires on my F250 FWD, and it shakes when im in over drive and it kinda shakes when im out of overdrive and im doing 30-40 mph and i don't know whats wrong with it, and i want to get it fixed before i start plowing this winter.
The easiest thing with a vibration issue is to check U-Joints for slop and check tire balance. Move on from there and check things like mounts, balancer pulley...etc.
