Now my truck won't even turn over
I have a 79 F150 (302/auto) I bought about 4 weeks ago. I just spent the last few days rewiring the rear lights and was going to to go put some gas in the tank. But I noticed it started to idle erratically and when I push down on the pedal it gets worse. I pulled the inline fuel filter off and I could see the rusty colored gas. I walked to the auto parts store and bought a new filter. I installed the fuel filter ('IN' side toward the gas tank). I started the truck and pulled out of the drive. It was idling very rough and finally the engine stalled. I tried to restart the truck but it won't even turn over. I cleaned all the contacts from the battery to the starter. Any suggestions?
This is a forum, not a text message!
But I agree, if you're getting a click, have the starter tested. Chances are this is unrelated to the fuel issue - your fuel tank can be full of mud, and the starter should at least crank.
I cleaned all the connections and put some dielect. grease on them too. I will put the battery back in in the morning. Decided to strip and repaint battery tray while I was in there.
Like most of the time as I am working on pulling something apart I start 3 or 4 new ones, lol. Thanks all, I will let you know if that helped tomorrow.
Why? The "click" sound is the plate inside shorting the two contacts together. This is what's supposed to happen.
1.) The battery is good. Good thinking though, sometimes it is the simple things. 2.) To have my starter checked I take it to a shop and have them look at it? Not trying to sound stupid, but I am not a mechanic.
3.) If the solenoid is not the problem I am only out less than $10 and I shouldn't have to worry about it in the near future either.
4.) I do appreciate everybody's thoughts and suggestions.
