64 4x4 brake line mess
Need help cleaning this mess up. I would like to get away from all these adapters. Is there a master I can bolt on that will accept the same fittings as the wheel cylinders and rubber brake lines.
http://i1229.photobucket.com/albums/.../imagejpg2.jpg
http://i1229.photobucket.com/albums/.../imagejpg1.jpg
I see in your pictures that the MC has been changed to a double; and one of the extra fittings is for the brake lights. To get rid of that set of fittings; get a brake light switch that mounts on the pedal and does not work off the brake pressure. Look at a mid 70's truck brake pedal. My son and I did his F100 2wd this way by changing out a pedel from my 73 parts truck.
Dancingchicken
07-03-2009 11:07 PM
