What can I do to my 460?
I've just gotten my first truck with a 460. Its a 1991 f-250 4x4 extra cab. The power it has down low is incredible. But when on the curvy hilly roads of central Missouri, it tends to get pretty bogged down towing trailers totalling about 6000 lbs. It has manual 5 speed tranny. Is there anything I can do to give it some more power when towing?
Keep the 460 at least 3000 RPM at 60 MPH under load and it will pull fine in it's stock form if all is ok.
Only thing you need is to put in in the correct gear and RPM for the load applied .
If it is below 3000 you are in the wrong gear!!
Also make sure you have around 45 PSI of fuel pressure if it is under a load.
Before you start changing anything mske sure the engine and fuel systems are up to par.
By the way, a loaded trailer should be pulled at 55 - 60 mph to keep things safe for all concerned.
on
As far as checking what gears you have, you can look them up from the door tag as bashby said, or check the code on the rear axle tag. If it's possible that the gears have been changed over the years by a previous owner, do the following:
Chock front wheels.
Place the rear axle on jackstands.
Put trans in neutral.
Make a mark on the driveshaft and a mark on one of the rear tires.
Count the number of driveshaft revolutions required to make one revolution at the tire.
~3 1/4 revolutions = 3.27's or 3.31's
~3 1/2 revolutions = 3.55's
~3 3/4 " " = 3.73's
~4 " " = 4.10's
Etc., etc.
Oh cool. I didn't know about all those ways to find out. Well, the rear end tag was really rusty. But I think the closest I saw was something that MIGHT have said 3 L 55. This is the sticker on the door jam. Here is a link to a pic of the sticker. truck tag | Flickr - Photo Sharing!
What does it show? I dont see the gear ratio on it.
3.55 is fine for cruising down the highway and light towing. Despite the fact that the 460 has incredible low end torque and the fact that you have a five speed, my personal opinion is that 3.55's are too low for what you're doing with the truck. Depening on how often you tow and how much highway driving (65-70mph cruise) I would recommend at least 3.73's if not 4.10's. Limited slip means that inside the diff there are clutch packs that limit slip between the two axle shafts, that means two black stripes on the pavement instead of one.
