Help With Paint Crack
Old Aug 1, 2011 | 05:14 PM
Jag Red 54's Avatar
Jag Red 54
I noticed that there is a small star-shaped crack in my paint. It is about the size of a nickle and is barely noticable unless you get the light reflecting at just the right angle. I would like to get it fixed before it gets worse. The paint is about 5 years old and is a single stage lacquer.
My question is: Are there any nifty fixes (tricks) that a paint shop can do short of removing and repainting that spot?
Thanks, Jag
Old Aug 4, 2011 | 07:47 PM
rabiddawg's Avatar
rabiddawg
I am not aware of any "tricks" that could be done to fix this. Not knowing where the crack is, I would say the best repair would be to sand it down to bare metal, feather the edges back, prime it and repaint.
If it is laquer, make sure the products you use are ok to use over laquer paint. My paint lines specifically state "do not use over laquer".
Old Aug 5, 2011 | 11:33 PM
Chaosracing's Avatar
Chaosracing
What material is this cracked paint on? When its cracked that big, I usually have only seen that on rubber or plastic bumpers caused by flex. Now if its on steel, there might still be flex involved that caused it to crack like that. But then it could also be the paint that was used as well. Old laquer would crack due to age and weather exposure.
Old Aug 13, 2011 | 09:39 PM
canadianelbow's Avatar
canadianelbow
star shaped cracks are a sign of rust building...... pics?
Old Aug 15, 2011 | 09:40 AM
Jag Red 54's Avatar
Jag Red 54
I tried, but the crack is so small it's not showing up in the photo. I guess that's a good thing. Jag
vidaliaman
Paint & Bodywork
Aug 23, 2020 09:17 AM
chaser1602
Paint & Bodywork
Nov 6, 2008 10:34 AM
preppypyro
Paint & Bodywork
Nov 11, 2005 08:30 PM
Chevythunder7578
Paint & Bodywork
Jul 24, 2004 09:21 AM
Copycat
Garage & Workshop
Jun 22, 2004 10:25 PM
