1967 F250 camper special
I've been looking around for a toy here lately and I ran across this :1967 Ford f250
Is it really what he says it is?
What are some things I should look for if I can get ahold of him and go look at it?
I will use it as just a "sunday go to meeting" truck and drive it some here and there, and maybe some farm work.
I know a decent amount about the dents but barely anything about the bumps.
And lastly what do you guys think of it?
Thanks!
Thanks!
If you need a big flatbed it could be the truck for you. I believe the 67 still ran the 352 not 360 and would have had a FMX C-O-M auto tranny not C6.
The odometer goes back to -0- every 100,000 miles so how many times has it done so? Some of the CSs did haul a camper (only) and didn't rack up a lot of miles, it that one of them hard to say.
Underneath is where you want to look for rusting, floor pans, rad. support, cab corners, under door hing area. May not be a lot.
I'd say it could be a good farm truck candidate but to restore not so much. IMHO
John
John
If you want it go for it. Yes the heads can be swapped between many of the FE engines. If you decide to buy drive it and don't worry about swapping the heads until you have to.
Did the seller address the wrong year engine tranny issue?
If it didn't do anything but tote a camper til the mid 80s that was still 25 years ago.
I have seen much worse deals & taller tales than that.
John
John
The heads will interchange but there is differences in the heads chamber wise regarding CC's and valve sizes. The only FE heads that were came with factory "induction" hardened seats were the D2TA heads. Run the heads you have now it takes a while for the unleaded gas to push the seats in.
I will thow in my $.02 on this. This shuold be a 68 or 69 by looking at the heater controls. These are the slide levers style. Where the 67 had push/pull type of controls. Also the drivers door has a squeeze type of door opener in the armrest. The 67's had a crank type of handle.
Without seeing the grill this could be as new as a 72.
This may have the 360 and C-6 as advertised.
Don't expect much for gas mileage. My F-250 C/S with a 360, NP435 4 speed gets 10 no matter what. At least it is consistant. Mine also ahs rebiut heaver springs and i do not think the ride is harsh o rough.
Good luck. Tim
Good luck. Tim
Previous posts are correct, truck is not a 67. 67's had door handles like a '66. Here's a deal on a 67:
Ford 1967 f100 Ranger
