General Automotive Discussion
Front suspensions
Old 07-26-2011, 06:06 PM
jmikeyj4's Avatar
jmikeyj4
jmikeyj4 is offline
Front suspensions
so ive been wondering what you guys think of different front suspensions such as twin I beam, independent, and straight axles??????
Old 07-26-2011, 11:26 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,584 Likes on 1,292 Posts
I think each is the best idea/worst POS ever put in a vehicle, depending on what it is.....
Old 07-26-2011, 11:35 PM
devino246's Avatar
devino246
devino246 is offline
My truck has TIB's. They seem pretty good to me.
Old 07-27-2011, 12:43 AM
ford2go's Avatar
ford2go
ford2go is offline
I don't know that much about the, but IFS seems to be the norm for most vehicles these days. Probably for some prety good reasons.
TIB was supposedly pretty rugged, but I have heard that there is an issue with 'jacking'. I'm not sure what it means, but it doesn't sound good. I think that it only comes into play in high stress situations. I had it on a couple of trucks, and I had no problems.
Straight axles are apparently the strongest, and you'll see guys on FTE converting to them. They're still used in heavy trucks I believe. I think that they're far from ideal for lighter vehicles. I also don't think that they handle all that well on twisty roads and the like.
Just my (uninformed) .02
hj
Old 07-27-2011, 09:05 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
Ive owned all three. IFS has the best ground clearance and can have the longest travel but is the most complex, with four CV joints. I actually liked the TTB for offroad, but the highway handling and tire wear issues are its downfall. Solid axles, especially with leaf springs have insufficient travel and I was always hitting the bottom of the housing on rocks. This is my stock experience with Ford and Toyota 4x4's. I do not modify my vehicles, so no slamming or lifting way in the air.
On a 2WD, IFS is not at all complicated and I think its the only way to go. GM has used it on light trucks since 1960.
DCP
50
11-10-2015 06:08 PM
Vinford
41
06-25-2012 06:22 AM
jack71
40
09-06-2005 05:47 AM
davethecow
08-04-2005 09:27 PM
4WD67F250
26
02-07-2004 03:13 PM
Quick Reply: Front suspensions
