Glow shift color change
Old 11-22-2010, 08:03 PM
Mydiesel250's Avatar
Mydiesel250
Mydiesel250 is offline
Hey guys, so I've been doing some searching but not comming up with the answers I need. Ive installed glowshift 7 color changing gauges. I can operate the color selection, and the auto change/fade option. However when I set a desired color it wont stay on that color after I turn the truck off? I assume Ive got a wiring issue somewhere. Anyone had this problem, or can throw some adivse my way? Ive had these installed for about 8 months and the color issue has never bothered me, until NOW! Thanks in advance
Steve
Old 11-23-2010, 05:43 PM
ReAX's Avatar
ReAX
ReAX is offline
I haven't installed a tach in a while and never tried that one, but here's what I remember.
You should have atleast 4 wires, Ground, Illum, power and signal. Hopefully they went a little above that and did Ground, constant power, switched power and signal. Unless you have a constant power source, it will not remember your settings.
What are your wire descriptions?
Old 06-24-2011, 03:40 AM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
Steve
Pics of your install? I have a 2000 Excursion and I am thinkin about the quad pillar with oil temp, oil press, water temp and trans temp.
Old 07-19-2011, 11:44 PM
bigred1992's Avatar
bigred1992
bigred1992 is offline
Hey, don't mean to jack your thread here, but I have a glowshift tach in my 92. It reads low, anyone else have this problem? Fixes? They sell a signal filter which may help, but I don't know
Old 07-24-2011, 01:53 AM
Mydiesel250
I havnt been on in a while but heres an update. For one reason or another the gauges couldnt handle the fluctuation in voltage that the truck was putting out. I went to radio shack and bought a $1.60 12v voltage regulator. and BOOM no problems, its been running prime ever since.
Old 07-24-2011, 07:59 AM
bigred1992's Avatar
bigred1992
huh, thanks a lot. I'll have to try that. I have my pillar apart right now to put in a real oil pressure gauge and I thought that I should try to fix my tach as long as I had access.
bismic
06-24-2018 04:02 AM
jt371
07-27-2011 08:09 AM
kontoboy
09-12-2010 10:58 PM
Damonkr
03-25-2010 09:04 AM
BlackJeep
50
06-18-2008 05:22 PM
Quick Reply: Glow shift color change
