81 bullnose ignition bypass?
hey all, just picked up a 81 f100 with a 3 on the tree a few days ago, and well, to say the least the ignition switch isnt there, but i found a way to somewhat bypass it, theres a bar that the ignition is suppose to operate, and since the ignition is gone, it moves freely with some pliars, but absolutely nothing happens when u push it into the start position, so it will only start up if u have 1 person hold the bar in the start position, and have another person jump the solenoid, i tried just jumping the solenoid with the bar in the on position, but its as if the coil isnt getting any power and it will just crank, so any easy fix to this? i could make a jumper on the solenoid with a button and run it inside the cab so i dont need 2 people to start it, but I would still like your guy's ideas!
The parts stores sell ignition tumblers with a new set of keys to go with it. Once you get that part solved you can figure out if you have a neutral safety on the clutch or not. They say the early trucks didn't have them, but the red/blue wire is the one that gets power in the start position and runs out to the solenoid.
Hotel
32
10-03-2012 09:38 PM
Olbeater
11-01-2010 05:31 PM
Muddn351
81
07-31-2004 11:04 PM
