Gas Mileage
I have had three 460 powered trucks. An 81 f100, 2wd w/460 & auto, 3.00:1 gears getting 14+ mpg. A 79 f350, 4wd 4spd, 4.11:1 gears getting 8+ mpg. And currently have a 96 f250, 4wd auto w/OD, 4.11:1 gears and 8- mpg. My brother and I did the conversions on the 81 and 79 as well as built both engines. The engines were mostly stock with a mild towing RV style cam grind. All tire sizes were close to stock and the speedo's within about a MPH known accurate one. To be fair, in addition to the gears, the 81 was a SWB light duty truck and weighed about a ton less than the others.
with a trailer at 60-65 it will get about 7.5mpg
with a heavy load at 55-60 it got about 6.3.mpg
look back through the threads, there was one about mileage when towing and there was a lot of feed back in that thread.
a search for my user name would probably find it, if you like.
sounds like gears can make quite a difference.
enjoy!
gears351
05-11-2015 09:37 PM
460 FORD MAN
77
09-08-2012 11:02 AM
Mitchellmx36
03-24-2010 06:14 PM
Sporttruck
09-17-2001 03:01 PM
