Stalling issue
Old 01-22-2012, 01:38 PM
Jeremy.Abraham's Avatar
Jeremy.Abraham
Jeremy.Abraham is offline
Stalling issue
I have A 00 f150. It runs fine in park and reverse, put when put in drive boom stalls. I have already cleaned iac and replaced tcc. Put on code reader and 2 codes cOme up. P1747 and p0743. Any advice?
Old 01-22-2012, 10:22 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Well yes.
Both codes, if you are accurate, are transmission fault codes.
They are not engine codes so working on the engine won't solve anything.
You need to take it to a transmission shop for repairs.
The 743 code is trans torque converter clutch failure. Likely locked on causing the engine to stall.
The 1747 is the electric pressure control solenoid (EPC) is short circuited.
With faults like this it will stall the motor by the load it presents to the motor.
And-and put my check in the mail please!.
Good luck.
gtex
08-19-2018 07:40 AM
julienf
11-13-2013 10:26 AM
Slip ford man
02-08-2011 02:58 PM
djbeck88
17
02-02-2011 05:00 PM
Quick Reply: Stalling issue
