shifting speeds
Old Jul 25, 2011 | 09:44 PM
BIGskinny's Avatar
BIGskinny
shifting speeds
what speeds should an AOD trans be shifting at? mine will go into overdrive at 35 that good or bad?
Old Jul 26, 2011 | 03:13 AM
Ken Blythen's Avatar
Ken Blythen
I have a C6 in my F250 now, but it did have an AOD.
I found OD to be impractical & almost never used it with my rear axle - 3.54, 31" tires - & 60mph local limit.
Even at higher speeds (eg 75mph, so rpm's were better), it seemed to me that you were fighting wind resistance so there was no fuel saving in OD anyway.
With your truck at 35mph in OD (assuming 27" tires), you are only doing 1000rpm; & with no torque multiplying in OD.
Personally I think those rpm's are too low......particularly for a 302.
Old Jul 26, 2011 | 04:53 PM
BIGskinny's Avatar
BIGskinny
Trucks got 31 ones all the way around. I know nothing about AOD trannys. Just thought it was a little odd to be in OD at 35mph
Old Jul 26, 2011 | 05:10 PM
Conanski's Avatar
Conanski
Yeah the stock setting put the trans in OD at about 35mph. The AOD is controlled by a cable link between the throttle body and transmission called the TV cable, it modulates line pressure inside the trans and that affects how long each gear is held and how firm the shifts are. If you increase preload on the TV cable even just a little bit each gear will be held longer and shifts will be firmer. The adjuster is at the throttle body on the cable that comes straight in from the back, you can experiment with this setting all you want as long as you don't drive the vehicle with the cable disconnected or with preload at zero, though the stock setting should be considered the minimum.
Old Jul 26, 2011 | 05:11 PM
rla2005's Avatar
rla2005
I am not that versed on the AOD as well. Perhaps the TV cable needs adjusted?
Old Jul 26, 2011 | 05:12 PM
rla2005's Avatar
rla2005
Now there is the best advice.....
Old Jul 26, 2011 | 07:39 PM
BIGskinny's Avatar
BIGskinny
Hmm. I'm kinda tempted to play around with it. I mean the shifting don't bother me. It's just at times it'll like short shift and bog me down some.
THE BLUE HEAP
Jun 24, 2013 02:31 PM
jrlowscot
Aug 16, 2009 05:59 AM
rustee90-150
Jun 22, 2009 06:25 PM
toeyesblind
1978 - 1996 Big Bronco
Oct 5, 2003 07:37 AM
84xltjeff
Jun 8, 2002 07:53 AM
