can anyone help me on figuring out why my truck shifts perfect until it gets into overdrive, then it starts shifting in and out of o.d. like its going into passing gear. i have replaced the speed sensor on the rear end housing, replaces the solenoid pack. also my speedo jumps everywhere at any speed. thanks for any help on this.
have you inspected the tone ring on the rear end? i have seen 2 different trucks have tone ring problems which cause the vss to go haywire. worth lookin at at least
Thanks for the quick reply Ill check that. Would it get desturbed doing the brakes? We had the axels out and both rotors and calipers took the bearings out and lubed them and cleaned them and put it all back together.
