I have a 1955 F250 that I put a 1968 Dana 60 rear in, I am in the process of rebuilding the brakes, I have bought all new parts. I just completed the left side. It's been awhile since I took everything apart so I'm going on memory, I know I should have taken a picture. Thats why I'm here, anyone have a picture that I can use to compare? Thanks
Dana 60 C8TA-NG 603045-5 3.73
Came out of a 1968 F250
Funny, I found that same diagram when I did a search for "Bendix" brakes. That diagram is close but not what I have, I'm pretty sure I have it right from memory. The self adjuster kit that I bought had a diagram that is what I have. Have a little problem with the right front, as I mentioned this is a 1955 F250, I put the 1968 Dana 60 in it years ago. The front brakes are the origional single servo type. The rear brakes are 12 1/8" X 2" The front were 12" X 2" since I could not find 12" X 2" brake drums for the front I went with 12 1/8 X 2" drums. I installed 12 1/8 X 2" brake shoes and drums on the front, everything went together fine. When I put the drum on the RT front it went on fine but when I put the wheel on it will not turn very easy. Guess I'll take it apart and do some measuring. Thanks for the help!
