Castor increase on leaf-sprung Superdutys
Being in the position of having to replace my ball-joints, or so I suspect, in the next month or two, here's a big question:
I've read here where some people increase the castor on the leaf-sprung trucks to get more "centering" of the steering wheel, and helping the inherent wander of not having enough castor.
Generally speaking, I've heard 2 degrees to be the correct amount.
Now, knowing my front-end is currently perfectly aligned, and assuming nothing else changes that, including changing the ball joints (theoretically), I should be able to take the existing alignment cams and figure out what I need.
But that's not what this thread is for, it's to see if anyone has done this, and if so, how it helped...
Thoughts/comments?
Thoughts/comments?
But one of the problems with the leaf-sprung trucks was last of "centering" especially on the highway, and one way to help that, of course, was castor.
I gotta go do a long detailed search of FTE
Looks like this:
I believe that Ford has the same thing available, of various offsets. If I take it apart and look at the cam, it is marked to designate offsets, so I can just get the one I need that adds 2 more degrees to the castor.
I think
There is a cam inside the hole that the top balljoint goes through.
Looks like this:
I think
Looks like this:
I think
on
Thoughts/comments?
Thoughts/comments?
Subscribed.
My truck was never great at centering from the day it rolled off the dealers lot. (Neither of my dads SDs centered great either) Just checked my ball joints they are tight yet, which surprised me. I get some wander mainly when loaded down good, at or close to max GVW and towing a boat. I suspect the tires I have are currently are the main cause though.
Fandini
05-02-2015 09:19 AM
seymoremud
03-15-2004 06:44 PM
