Broken Rear Leaf Springs! Temp Fix?
Old 07-22-2011, 01:30 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I recommend getting the bushing kit. You'll need the new pins and shim bolts. Why reuse the old 50+ year old hardware? After you remove the old pins and bolts, you'll find that they've been worn. If you're spending hundreds on new springs, what's another $80 for the kit?
Old 07-22-2011, 01:35 PM
polarspeed's Avatar
polarspeed
polarspeed is offline
polarspeed is gaining momentum as a positive member of FTE.polarspeed is gaining momentum as a positive member of FTE.
I am so glad that I am not a surgeon and can abuse my hands. I just need my brain and my mouth do do my job!
Thanks for the link. I have it bookmarked!
Steve
Old 07-22-2011, 01:49 PM
51PanelMan's Avatar
51PanelMan
If you were a surgeon, you'd have the work done for you.
Doc's Avatar
Doc
Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Uhm........I guess that makes me a rebel. I perform minor surgeries on humans just about every day, and then I perform surgery on my trucks and my farm equipment just about every night.
You'll be fine replacing your springs. Just get yourself a BFH and a long punch or bolt.
Old 07-22-2011, 02:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Actually, with nothing of the old stuff being saved, I'd consider a Sawzall and a pack of blades!
Old 07-22-2011, 02:31 PM
51PanelMan's Avatar
51PanelMan
Still have to get the front shackle pins out.
Old 07-22-2011, 05:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That's what the Sawzall is for. Just run it along between the spring and the hanger, problem solved. I had to cut two pins, twice each, with a handheld hacksaw blade in my youth. Talk about rough on the hands, I recall it took 2 or 3 hours a side. (British cars... )
afonda
04-19-2017 10:23 PM
larz12345
12-05-2016 01:30 PM
brian42
06-24-2016 09:59 AM
93F150&69Stang
11-28-2015 01:31 PM
HKusp
29
08-24-2010 11:58 AM
Quick Reply: Broken Rear Leaf Springs! Temp Fix?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
