84 to 93 swap / pictures
  #61
Old 12-26-2011, 04:37 PM
Mtnplow's Avatar
Mtnplow
Mtnplow is offline
Needs a cam
  #62
Old 01-09-2012, 03:34 PM
Mtnplow's Avatar
Mtnplow
Mtnplow is offline
Ok Crane Cam installed, new chain, old timer crank gear (pre-72) thanks Bill "85LebaronT2" new lifter and it sounds and runs amazing. Now maybe I can bolt the drivers seat in and figure out the oil pressure gauge and windshield wiper motor problems. thank you God for not letting it snow or should I be thanking AlGore ....lol .
  #63
Old 01-09-2012, 07:28 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
Larry, which oil pressure sender do you have? If the 84 had gauges, you will have a large bell shaped sender that is a variable resistor. If you had idiot lights it will be a small one with wrench flats. Either way, for 89 up gauges you need the 89 up sender. The oil pressure "gauge" after 89 is simply a pressure indicator, sort of a reverse idiot light.
  #64
Old 01-10-2012, 09:58 AM
TheKirbyMan's Avatar
TheKirbyMan
TheKirbyMan is offline
I think there's a way to set it up where the 89+ "pressure indicator" gauge can be made to read actual pressure. I seem to recall it involving switching out sending units or something..
  #65
Old 01-10-2012, 12:11 PM
lavatan's Avatar
lavatan
lavatan is offline
I would go aftermarket. That way you won't just have a either a light or a gauge that means nothing with a L|______|H indicator. I like to have numbers...
  #66
Old 01-10-2012, 02:01 PM
TheKirbyMan
This is true.
My factory oil gauge moved about like a pinball paddle....once I hooked up an Autometer gauge I beheld steady readings of 50-70psi. Granted, the IVR on the stock gauge cluster isn't exactly a precision device, but before the Autometer I never knew what was really going on.
  #67
Old 12-02-2012, 07:46 AM
Mtnplow's Avatar
Mtnplow
Mtnplow is offline
Been way to long had many other projects that got in the way, so on to better things, here is the plow frame we came up with for this beast.
  #68
Old 12-02-2012, 07:48 AM
Mtnplow's Avatar
Mtnplow
Mtnplow is offline
due have a strong vibration that gets stronger in the drivetrain I have to figure out, hoping it's a tire issue.
  #69
Old 12-02-2012, 01:59 PM
85lebaront2
What speed is it showing up at? Does it vary with changes in load, accelerating vs decelerating?
  #70
Old 01-26-2020, 08:38 PM
TFernandez80's Avatar
TFernandez80
TFernandez80 is offline
Originally Posted by 85lebaront2
Brad, the speedometer is operated by the ABS sensor in the rear. It goes to the PSOM, not PCM, from the PSOM a speed signal is sent to the PCM and speed control. I know, because I just put a 95 dash in my 86 and since it had spun a rear hub bearing years ago, changed the rear end to a later housing in order to have a working speedometer.
Please contact me! I am currently going to attempt taking my first truck (84 f250 2x4 single cab 351w) body and putting it on my current daily (95 f250 4x4 351w single cab) the 95 body is toast. But my 84 is mint. But I want a twist. Put my 95 interior into the 84 cab.
  #71
Old 01-26-2020, 09:50 PM
85lebaront2
Ok, I did essentially that, I have a 1995/6 interior in my 1986 crew cab. A lot of the details are in my thread on it. I haven't been super active on here in quite a while due to a bunch of changes in the way the site is run.
  #72
Old 01-29-2020, 08:35 AM
TFernandez80
Which thread of yours is it under??
  #73
Old 01-29-2020, 09:04 AM
85lebaront2
  #74
Old 01-29-2020, 01:02 PM
ewalt98's Avatar
ewalt98
ewalt98 is offline
Kind of a bummer here.. Got to reading this revised thread and was looking forward to seeing the OP's final result!
crm318
49
07-24-2023 11:05 PM
BadBehavior135
New Member Introductions
10-14-2015 08:27 PM
ReBilld
44
02-11-2012 03:51 PM
Vinford
Garage & Workshop
11-20-2010 07:06 PM
Csteptoe
11-10-2009 05:49 PM
Quick Reply: 84 to 93 swap / pictures
