Whoo-Yhoo, i got my tuner for my 3.7 ordered today
I'm a firm believer in tuners and i'll see if it does the same wonders to a 2011 3.7 motor like it did to my old 2006 5.4. i mean, it is doing wonders for the mustang and i'm assuming it will too with the f150.
i ordered her in a 87 economy tune for the highway driving, 87 performance/towing, and 91performance/towing.
feedback to come!
feedback to come!
feedback to come!
feedback to come!
I've always put the stock tune back into the truck taking it back into the dealer. i don't believe the system is tracable to where you can tell it the PCM was reflashed to a custom tune.
i also went with a SCT X3 with custom tunes from 5startuning.com. not too many doing the tunes for the 3.7 for the f150. too different of a tune than the 3.7 mustang though.
on edge programmers, i've never heard of anybody having issues running programmers and then having issues with warranty work even with the motor and trans. but knock on woods!
If those 'flashes' do not correspond to the data in their OASIS system, you're screwed.
That really depends on your dealership. Where I live the local dealers understand that the country boys are going to play with the trucks. Cats are missing, air boxes are enlarged, pipes are bigger and electronics are going to be used. If fact they will install just about anything you ask within reason. My truck has an Edge box with after market pipes along with dealer installed leveling kit. They don't seem to a have problem with it. Chris
Why gamble? There's a real good chance this vehicle will go back for warranty issues before 5/60 is up. I'd bet on it. If it's a tranny or engine issue it wont be covered. Ford will be able to tell if you messed with the truck.
Maybe you'll get lucky and you wont have warranty issues. It's your truck do what you want. There was someone here who just recently had warranty work refused and his truck tagged/ warranty voided for mods.
To each his own.
To each his own.
a tuner is a untracable mods! i've brought in my truck before and just removed the tune before bringing it and i had no problems. now if i were to do mods like a CAI, throttle body/spacer, larger injectors, aftermarket intake manifold, and headers, i would assume so but all the factory componenets are intact.
i doubt i'll have issues (hopefully) my local dealership has told me in the past that warranty voids will have to be something from obvious abuse and extreme modifications.
thousands of 04-08 f150 users have gone to the sct/edge tuners without any issues and before their warranty were up.
ok i got the tuner today after returning from work and boy, did the first time loading anything took a while. and boy, does this thing move now.
i thought when i tuned my 2006 5.4 f150 was a big wow'sers, this tune for the 2011 3.7 f150 is a DOUBLE wow'ser!!!! all of the lag is gone, it holds the gears slightly higher and it accelerates much faster with the same light throttle.
i'd recommend this tuner for anybody with a 2011 F150 for any motor.
and if having a tuner with these trucks was a really big issue, nobody really would be buying them when they are still brand new and hundreds of people are already buying them. if people knew they were going to lose out on their warranty, then nobody would buy them and the tuning companies would be out of luck then until peoples warranties run out.
if something were to go wrong, say like a bad stall, i don't think as simple as delaying shift points will cause that problem so they'll probably take care of the problem.
now i can see if i were to change the throttle body and and try to claim a problem with something in that parameters, i can see them not taking care of it.
but again, if tuners were a huge problem with warranties, nobody would be doing them until the warranty is up. hence, tuners not even thinking about making tunes for the when the car/motor is still new.
If Ford wants the dealer to investigate (because of the nature or expense of the required warranty work) they can and will determine the number of times vehicle was flashed and when it was flashed. Please note this will not be a dealer decision.
LxMan1 is correct, but when Ford (please note it is not up to dealer discretion) denies your warranty claim it's up to you to prove the tuner did not cause the failure.
The key fact is most experienced F150 tuners DO make damn sure their tunes are safe and thus very few owners ever have a problem. But the question was, "what if?".
The answer is you are screwed and the dealer won't be able to do anything to help you unless THEY decide to pay for the repair themselves.
