Paint removal?
Paint removal?
Hey guys! Im actually ovr in the 73-79 section but im not getting the answer im looking for. I have a 74 Highboy and it has two layers of paint. There are many rust bubbles and the paint is cracking all over. I need to get the paint stripped on the body and door jams. The interior looks 99.9% brand new still.
I dont want to sand blast. I thought about sanding but can u get down to the bear metal that way? And isnt there lead in the paint so you could possibly get lead poisoning?
I also need to remove surface rust from under the bed and remove this cheep bed liner (spray in type)...
Any help would be great!
try aircraft stripper available at autozone etc , get the gallon brush on . the aersol suxz.
wear eye protection ,thick rubber gloves, and don't get any on you !
oh you will need a natual hair brush to apply .
brush it on and let sit paint should bubble wait like 15 minutes then scrap with plastic putty knife to remove paint . oh i put flattened cardboard boxes on the ground to catch the stripper/paint . make sure you use it a well ventalated area it's knarley stuff .
