do I have a bent Connecting Rod - Pics
  #61
Old 07-27-2011, 05:18 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
#3 and # 5 have stamps on em but I cant make out whether it is actually a measurement or just random #'s It look likes #3 says .2. (but the dots are at the upper level of the 2) then 0301 (and tR1. Hope that makes sense.
  #62
Old 07-27-2011, 05:41 AM
hotroddsl's Avatar
hotroddsl
hotroddsl is offline
Those are just manufacturing date and part codes, it would be very clearly marked if undersized with the main/rod undersize, I'm assuming this motor came from the states? As that's the cardinal rule here so the next guy can order inserts or I'd the crank quickly! Same thing with pistons right on top STD. Or .030 ect... Or you could just put her back together and sell her as a good used motor she's probably got some good stock level miles on her I've seen PMRmotors go 500k+ and you've got internal pics and measurements to go with it! You could get 4500.00 for a motor like that up here with out the documentation that it's sound! Just a thought!
stevorino
57
06-16-2016 08:59 AM
ChunderDownUnder
Australia Chapter
17
06-08-2015 07:27 PM
vrsc
6.7L Power Stroke Diesel
60
05-19-2013 10:39 PM
Rellim51
08-24-2011 07:35 PM
arnegrant
04-02-2009 01:32 PM
Quick Reply: do I have a bent Connecting Rod - Pics
