Almost time to get tires for the F-250
i just ordered 2 new rear tires for my truck from tire rack, but i use 265/75R16's. i don't like the pizza cutters. i use Pirelli ATR Load Range E. i like them. i have had them off road in the mud and they do better than they look like they will do for sure. they are slightly more than $150 a tire though. i spent $350 for 2 tires with shipping to my door step b/c i will be mounting and balancing them myself. if i was getting someone else to mount & balance them then i'd be looking at another $40 to get that done.
I would go online to tirerack.com and pull up the tires you like.
I have never bought a tire from them but go to local shops and the match the price !
What I like about tire rack is after you select tire size you can select them and click compare.
Once you click compare you can go down and see how many revolutions per mile.
So you can change brands and sizes like 265/75-16 or even 245/75-16 for a stock 235-85-16 and depending on brand get higher or lower revolutions per mile !
I think the place with the best warranty is a green colored store ... Tire pros? Full warranty for life of tire not prorated on tread life!
If you can mount + balance them, here is a good place to buy from (about $80 to ship but still big savings).
Tire Rack - Your performance experts for tires and wheels
If it were me I would try to get a Light Truck tire instead (size should start with LT). They will carry a heavier weight rating, and generally will last longer in use on a truck.
That tire only has a weight rating of about 2,600 lbs per corner. Most LT tires will carry something more like 3100 lbs per corner.
If you don't haul or tow with the truck those will technically work, but they are not rated for the kinds of weight your truck can carry. They will ride nice though.
Look for an LT tire with a load rating of D or E.
IMO, I wouldn't run those Firestones. Put them on my girlfriends Ranger and had them on a Ranger at work. Both sets SUCK. Worn out at about 30k miles, not great traction on the street and really bad in the rain. That's just my opinion on them.
Also, like Nate said. Look for load range D or E. Definitely get load range E if you tow very much though.
Here is a link for some load range E all terrains at Tire Rack-- http://www.tirerack.com/tires/TireSe...75&diameter=16
howardsamycia
03-01-2014 12:20 PM
peckhamjusten
09-29-2008 06:40 PM
