Truck shuts off when driving. - Ford Truck Enthusiasts Forums
Old 07-18-2011, 11:57 PM
BlackCustom77
BlackCustom77 is offline
BlackCustom77 is starting off with a positive reputation.
Hello, I have been trying to get my 1977 Ford F-150 running smooth for the last month or so. The truck keeps dying on me while I'm driving. Sometimes it wants to die and then just comes back to life as I'm driving. I have changed all the spark plugs, cap and rotor, ignition control module, ignition coil to no luck. This is driving me krazy. Any help is greatly appreciated. Engine is a 302 Automatic.
Old 07-19-2011, 12:00 AM
brian1080's Avatar
brian1080
brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
Fuel issue maybe. That's how cars/trucks act when they get staerrved for fuel like on corners/hills
Old 07-19-2011, 12:01 AM
devino246's Avatar
devino246
devino246 is offline
devino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputation
Has the carb been rebuilt within the last few years?
Old 07-19-2011, 12:22 AM
BlackCustom77
thats what I thought at first, maybe fuel/carb issue, but when the truck dies. I check my fuel and its getting fuel in the carb. Acts as if its something to do with ignition. Bought the carburetor about a year ago, used but in good condition. Edelbrock 1405. The problem started about a month ago. It might need a rebuild. Thanks for the replies.
Old 07-19-2011, 12:54 AM
73f250highboy's Avatar
73f250highboy
73f250highboy is offline
73f250highboy has a good reputation on FTE.73f250highboy has a good reputation on FTE.
The tank sock on the end on the pickup tube might be getting clogged up... or maybe the fuel pump?
Old 07-19-2011, 10:56 AM
devino246's Avatar
devino246
Ignition module?
Old 07-19-2011, 11:15 AM
BlackCustom77
Yeah, that's the second thing I changed. Funny thing is, the problem stopped for a couple of days after changing the ignition control module. Truck ran fine with no problems, but then it started again. I bought a rebuild kit for the carburetor. Will be my first time rebuilding one too, so I hope I know what I'm doing. I really hope that is the solution to my problem. Thanks again for the input.
Old 07-19-2011, 11:21 AM
devino246's Avatar
devino246
These two links were really helpful for me.
Motorcraft 2150 2V internal systems
http://www.therangerstation.com/tech..._2150_carb.pdf
Old 07-19-2011, 12:25 PM
Thunderbird7480's Avatar
Thunderbird7480
Thunderbird7480 is offline
Thunderbird7480 is starting off with a positive reputation.
Agree its usually a fuel issue. Any smoke involved ever at idle, cruise or wide open throttle? Sometimes too rich can act the same as a fuel starved carb. Like if there is an internal fuel leak or a choke that isnt working right.
Old 07-19-2011, 01:10 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Have you noticed if you lose all electrical when this happens?
Old 07-19-2011, 11:11 PM
tude's Avatar
tude
tude is offline
tude is starting off with a positive reputation.
i had an issue the other day with my 460. i went to leave a stop sign, it died. i thought well coil is old thats got to be the problem, replaced it, fired right up took off. got to the stop sign again and died again, well it must be the ign module, tested it and it was fine..... all i can think is it was vapor locking. ill be wrapping the fuel line with header wrap maybe that will stop it.
Old 07-25-2011, 12:36 AM
BlackCustom77
Thanks everyone for your input, I successfully rebuilt my Edelbrock 1405. After reinstalling the carburetor, it still had the same problem as before. At this time I knew it couldn't be a fuel problem. Fuel was going through the carburetor fine. Well I believe I did find my problem. It was the wire going from the ignition coil to the ditributor. PO had moved the ignition coil to the fenderwell and when I bought it a year ago I changed all the cables and had to make my own cable from the coil to the distributor. I changed the cable and now the truck has been working fine since changing out the cable. It's funny how the simplest things always seem so hard to find. At least now I know what is new and replaced. Once again, thanks everyone for helping me out.
Daniel
Old 07-25-2011, 06:45 AM
co425's Avatar
co425
co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Keep detailed notes of what, how, what parts from
What year model etc and when you changed them. It will save your bacon later.
Old 07-28-2011, 09:06 PM
BlackCustom77
Well, hell. I thought I had solved my problem, but only to find out now I have another one. After the rebuilt and finding the ignition problem, now my truck is flooding at the carburetor. I have taking the top of the carburetor out to check the floats and they seemed fine. After putting it all back together, the truck seems to drive good for a couple of times and then floods again. I don't get it, I did exactly what was in the instructions of rebuilding the carb, did I miss a step? Any help with my problem is very appreciated. Just in case it's and edelbrock 1405, bought the carb used a year ago and had been running fine up until last week when I tore it down to rebuilt it. Thanks again. Floats were set at 7/16" and 15/16" per edelbrock, if there is a different setting for them please let me know. I have been online looking around and I found that the second setting is being set at 1-11/4".
Daniel
IDI Diesel
38
12-04-2015 10:11 PM
capriceragtop
31
07-26-2014 09:24 AM
scottl523
1968-2013 Full Size Vans
06-10-2014 10:29 AM
GSiron
06-10-2014 06:43 AM
Smook
04-02-2014 08:32 PM
Quick Reply: Truck shuts off when driving.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
