Places to look for cause of low MPGs
#46
You must have weak compression, bad cylinders, worn out injectors or something. My very heavy 14' box van with six tires, modified engine, php tuner, terrible aero dynamics is getting 13 - 17 mpg. Plus I am always into the pedal with 120 race tune on all the time. I usually can go 550 miles on 40 gallons. Thats 13.75 mpg. Believe me I am into the pedal constantly.
Have you tried spraying water around your intake plenums and watch for tiny bubbles?
#48
#49
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
#50
not that its a total wast of time but I have way to many other things to do.
now back to our regularly scheduled program:
Barney
#51
#52
Been using Diesel Kleen...love it...plus 2stroke oil....whata difference in made in reducing engine noise.
#53
How many miles on them? You would get some return on testing if you needed rebuilt or even purchasing new.
Riffraff Diesel: 7.3L HEUI Injector Flow Testing
#54
#55
Yupp. Thats about the sweet spot for injectors..
Maybe you should admit defeat and upgrade to stage 1s!
But yes, you can take them out yourself, its not too hard. And like posted above, Riffraff can help you get them tested.
#56
Riffraff will rebuild my stock injectors for $125? I assume that is $125 for all 8???? (please say yes Mr....) Riffraff Diesel: Stock Rebuilt Injectors
#57
Good to know! So they want $255 for testing and minor repairs? Of all 8 injectors?
For the $255 that is cleaning, testing, and new o rings. They would let you know if they will need rebuilt and you can get options from there.
For the $125 that is 1 rebuilt stock injector.
#58
I paid about 300.00 at Seattle Injector. But if you have some miles I would say pay the extra and get reman injectors instead of testing and putting back in old injectors.
#59
I will not test those injectors with amount of miles. Had issue with diesel shop that I told NO test and want rebuilt. But they end test then sit until I call to ask how long rebuilt injector would be. 3 days for mistake Then they process say that it will be $80 for test on 3 injectors I told no. They say amator is shot it wouldn't work correct until it warmer.
I wouldn't test it waste $ plus injectors in those are only good for about 150-250K miles until you are really strict maintain then it last longer.
#60
