You put s screwdrive thru the block? Your gonna need a new block soon. If the rest of the truck is as rusty as the block I think you may need to take a closer look at your frame. I suspect there is some hidden rot that you have not seen yet.
hey i havent been on in a while do to working weekends and school but ive started working on the truck again and now its just reassembly but i still need to figure out how i want to run the exhaust i have 3 ways in mind . also i and running LTs 14"bullets true duals. also thanks for the heads up on what those sensors were. 80 dollars later at napa....
Also i do realize i cant pipe it like that straight back. what do you think i should run?
do #3. use 3 inch pipe, 45s after the tire. Thats the set up on my truck, looks tough. Im gonna warn you, its gonna be LOUD. bullets arent much of a muffler.
I'll second what GNR22 said. It looks awesome, even of you dont put shiny tips on. What size exhaust will you run? Hint:go big or go home...lol k maybe not too big
