Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cooling System Guides
- Upper Radiator Hose Reviews
Reviews and comparisons of top products
Radiator Hose Orings?
Are there O-rings in what Ford calls "Radiator Coolant hose Retainer clip" where the two lower radiator hoses connect to each other below the radiator? It seems there would have to be. I have a very small coolant leak there. Not much, just basically staying damp. I'm not worrying about it that much unless it gets worse. I see that one of the latest TSB's is covering the o-rings under warranty and if there are o-rings in the retainer clip I could get them replaced under warranty.
Thanks
Thanks
o-rings
Yes where the lower hose splits there is a o-ring the same as the all the others The Ford short # is RTS-1077 The only difference with the old hoses and the new is where the upper radiator hose connects to the thermostat and where the lower radiator hose connects to the water pump inlet those connections are white, those white connections have two o rings in them AND are the newest updated models. Not only do those keep coolant from leaking out but just as important keep air from being sucked in. Though the lower rad hose is two piece when you get the updated lower hose you only need the part that connects to the water pump. Good Luck
75_92_95
07-22-2019 11:49 AM
75_92_95
1978 - 1996 Big Bronco
07-27-2017 12:09 AM
