Trailer Wiring Short; need help, please!
I have a 2 year old 5 x 10 utility trailer that apparently has a short in it. When you put on the right turn signal, it blinks and so does the left running light, not the turn signal. Everything checks out at the truck. I just don't know how to trouble shoot it with the ohm meter, as it has continuity across all three connectors any way you check them. The left turn signal works fine, the fourway blinkers work and the running lights work fine.
Would sure appreciate any help you guys could give me, as I'm heading across country to Phoenix next Sat.
Hope this helps.
