Rear Dana 60 Wheel Bearing Adj' Nuts...
There are TWO different types of these Rear Wheel Bearing Nuts. One is Dana 60 only thru 1968. The other is Dana 70 & 1969 and later Dana 60.
Lock washers are also required (should not use the old ones over again). Its tabs are designed to be folded over onto the sides of the hex nuts to secure them in place.
61-4252 .. Rear Wheel Bearing Nut-Dana 60 only / 1 13/16" thread - 2.38" Hex / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
KLIMESH MOTOR SALES in Calmar IA has 3 = 563-562-3241.
MANDERBACH FORD in Temple PA has 5 = 610-929-3659.
B6Y-4252-A .. Rear Wheel Bearing Nut / 2" -16 x 2.56" Hex / Obsolete
NOS PARTS LTD in Waxahachie TX has 5 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 50 = 513-731-3304.
61-1124 .. Lock Washer-Use with 61-4252 nut / 2 3/4" O.D. x 1 27/32" I.D. / Obsolete
FRIESEN FORD in Aurora NE has 4 = 402-694-3111.
NOS ONLY in San JOSE CA has 4 = Only number listed is 800-667-6659 (toll free-won't work from 'down under').
I called, left a message, asked for their regular number. Will edit it in when I hear back.
B6Y-1124-A .. Lock Washer-Use with B6Y-4252-A / 2 5/16" O.D. x 2 1/32" I.D. / Obsolete
GREEN SALES CO. has 49.
Green Sales (greensalescompany.com) ships "across the pond" via Fed-Ex. I dunno if the others will.
nogig
08-08-2019 07:21 AM
jakeharp
11-10-2017 01:28 PM
