decode warenty plate infor on Barn Truck
F10 = F100 2WD
J = 223 1V I-6.
L = Michigan Truck Assembly Plant.
570936 = 1964, assembled July 1964.
114" Wheelbase.
COLOR code blank.
F101 = F100 2WD, 4200 lbs. GVWR
181: 1 = Light Gray Crush Vinyl & Light Gray Rib Vinyl // 81 = 81A Standard Cab.
D = Borg Warner T-89C Medium Duty 3 speed Manual Transmission (special order).
12 = Ford 9" Rear Axle / 3.89-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
4,200 lbs. Gross Vahicle Weight Rating.
Cert. net HP omitted.
RPM omitted.
DSO omitted.
If you had posted the DSO, it would have 6 digits. The first 2 are for the Ford District Sales Office the truck was originally ordered from.
The last 4 digits denote a Domestic Special Order. The COLOR code is blank because the truck was painted a non standard color.
The T-89C trans was a special order if equipped w/the 223.
I would like to thank you for the information this is a lot more information than I ever expected to get. So far the information you provided matches the the truck, so It looks like I have the factory engin transmission and rear end. I have the DSQ # 210834. Again thanks I look forward to my first restoration project.
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
0834 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
The non standard color and the T-89C trans were both special orders.
on
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
1. Login to FTE.
5. Click Upload.
Pacecar1986
01-02-2017 05:56 PM
Pacecar1986
07-17-2014 08:18 PM
62FE4x4
11-05-2012 09:11 PM
Erich.Vongeist
06-24-2009 01:44 PM
